Thread: Water Softener for water fill
    Are there any problems with using soft water from softener to fill pool? I have very hard water and used in the past softened water. However, the pool guy tells me that it is no good to use water softener output to fill the pool. I am ready to replace the water (4 years old) after an AA wash planned for this week. Thanks.
    Richard, Temecula, CA
    28,000 Gal. In-Ground Black Marble Pebble Tec and tile, Intellichem with Chlorine and PH control, Pentair EasyTouch 8, ScreenLogic Wireless, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, Water feature spillover from SPA.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Water Softener for water fill
    There are going to be two issues with using a water softener.
    First, the volume of water that a pool takes well exceeds the volume of a typical home water softener so you will need to recharge several times.
    Second, you don't want to completly fill a plaster pool with softened water because at a minimum, you need 200 ppm of CH. So depending on the CH of the fill water, you need to figure out how much unsoftened fill to use and how much softened fill to use.
    Mark
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Have you looked to see if reverse osmosis pool treatment is available in your area?
    Love TFP? Become a
    TFP Supporter!
