Results 1 to 18 of 18
Thread: Water Fall for an Above Ground Pool has anybody tried?
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    I thru this question out last year also....has anybody tried or come up with a waterfall that could be used on your above gound pool?
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
    Feb 2008
    Denton, TX
    5,061
    Re: Water Fall for an Above Ground Pool has anybody tried?
    I haven't heard of anyone doing that. This is not saying that it couldn't be done. I am curious as to what it would take logistically.
    30,419
    It seems to me a normal decent pump (maybe not Intex) would have no trouble pushing the water up high enough but constructing a platform that would look nice without spending really big bucks might be the biggest problem
    22,548
    I looked into doing this, and if you have the parts and expertise to fabricate something it would certainly work. My thought was to build a tray like a cascading tub faucet on a larger scale and you could either build some fiberglass rocks around it or anything that strikes your fancy.
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    I was kinda thinking along those same ideas or something coming off an existing deck. I was just hoping someone may have alrady tried it and would have some answers or ideas.
    I know they do sell a resin prefabbed waterfalls than can sit on the edge of your inground but i dont think that will work for me.
    Wedding Cake Steps
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I always though one could put something together from the backyard pond aisle in most big box stores, they have all sorts of realistic plastic/rock waterfalls and spillways.
    Frenchie did ! His pool is put in ground but, I have waterfall envy. It's on his site http://www.myswimmingpool.webs.com/ Maybe, we can con him into pics and detals.
    Artesian pool 24' x 54'' buried in ground
    Pentair Dynamo 1.5 HP pump
    200 lb SD-60 Pentair Sand Dollar filter
    Taylor K-2006
    I had one on my ultra frame pool. i had a little deck coming off of the actual deck that the waterfall set on. I would not put one directly on the frame;as the weight could bend it.
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    Quote Originally Posted by poolboy24
    Do you have any pictures of it?
    Wedding Cake Steps
    Ill try to get some. As of right now the little add on deck is off and the winter cover is on the pool. I made two different designs of the waterfall box.
    Mar 2008
    Huntsville, Texas
    40
    Here's mine that I built and discussed in another thread http://www.troublefreepool.com/weeke...ct-t24387.html
    Here is a picture. It was a fun project and is still working beautifully.
    Oct 2011
    New Caney, Texas
    414
    That's really nice. Gives me ideas for when we get a bigger pool.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    Very Clever Idea!
    Wedding Cake Steps
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    I did something last year using the return on my pool and some PVC to make a sort of fountain in our pool but on the side. I am guessing you could possibly do the same if you could figure out a rig.
    15' RND 48" AGP 5,300 GAL
    16" Sparco Sand filter,I got a new pump in 2010, but not sure what it is
    Successful Convert to BBB and lovin it!
    I will be adding a waterfall/splash area with my inground aboveground. Still a work in progress, hole's dug, still leveling and waiting on my liner to arrive. I'll tee off some return to supply it. I'm using the old liner to waterproof a cement board deck that overlaps the side of the pool. No pics yet but will update as I progress
    When the only tool you have is a hammer everything starts looking like a nail.
    Doughboy 16x24 "Aboveground Inground" in progress...
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    Quote Originally Posted by gtojohn
    Looking foward to seeing them!
    Wedding Cake Steps
    I am actually planning on doing one for my inground aboveground. My 22' x 52" ProSeries is in a pit lined with a brick wall, I also have about 15" between my liner and my brick wall to put down deckbloks and 4x4 posts to use as supports for the framework of the waterfall.
    I've done a custom outlet manifold with 3 return lines that go to my pool:
    1. Original return (at the water line, near the skimmer).
    2. An Aqualuminator flow-through light (located about 6 feet away).
    3. The return that will go to my waterfall.
    I plan to use cinderblocks or something similar as a frame, and then apply some limestone around it with mortar as a sort of verneer. There will be a bucket or small tub that the water line pours into, and then it drains out onto a series of rocks that overhang over the edge of my pool frame (but do not rest on it).
    Water would ideally overflow the small tub, pour out, go down the fall, and into the pool. A removable cap rock(s) would hide all the hardware but still give me maintanance access.
    Most of the ones I've seen built for conventional inground pools are made that way, brick and mortar for the support structure, stone exterior as a decorative verneer, and a slab (or steps of slab) that the water pours down into the pool.
    i did one search my post turned out reallynice
    15x30x54 AG,2HP2SP PUMP 400LB SAND FILTER
