Thread: Question about my R-0001
    Feb 2012
    Stowe, VT
    59
    Hey everyone, I've been reading through this forum for quite some time now, and for the most part could find answers to my questions. This one seems to be an oddity that maybe I just haven't looked hard enough to find an answer.
    Any way, I've been using a K-2005 test kit by Taylor to do all of my pool readings on both the hot tub and pool. When I test the chlorine in the pool using the R-0001 my sample turns cloudy immediately. After adding R-0002 I'm able to get a clear reading. However this does not happen when I test my hot tub. Any idea as to what this might indicate? Since I've taken over, I've switched from trichlo to sodium hypochlorite, as these bodies of water are indoor.
    Pool levels -
    FC: 2.0
    TC: 2.0
    CC: 0
    Alk: 100
    pH: 7.1
    Cal hardness: 650
    Temp: 85 F.
    69,000 Gal gunite indoor IG pool.
    5 HP Emerson - Pentair Triton II Commercial TR140c Sand Filter x2
    5,000 Gal gunite outdoor IG hot tub
    2 HP Sta-Rite - Pentair Triton II Commercial TR140c Sand Filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Question about my R-0001
    Welcome to TFP!
    The DPD #1 reagent is a phosphate buffer for pH while the DPD #2 reagent is the DPD organic dye. Perhaps your Calcium Hardness (CH) is high since a phosphate buffer could cause cloudiness if CH is high.
    I assume you know that it would be better for you to get the FAS-DPD test. Since you already have the Taylor K-2005, you can get just the FAS-DPD Chlorine & CC test at tftestkits.net.
    Feb 2012
    Stowe, VT
    59
    Quote Originally Posted by chem geek
    Welcome to TFP!
    Thanks! I did not realize that using FAS-DPD was that much better. To be honest I've been a little nervous about using the powder, I shall purchase some and give that a try.
