Results 1 to 10 of 10
Thread: Unusual white deposits on new plaster..
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Then pool was resurfaced about 3 months ago. every week I have to knock these white deposits off the wall with the pool brush but they keep coming back and in the same place. Anyone know why this is happening? Thanks!
    We had problems getting water to fill this pool. The rain water tank ran out and we were forced to use well water which was brackish.
    These are the latest levels:
    CSI: -0.26
    FC: 4.5
    CC: 0
    pH: 7.7
    TA: 70
    CH: 300
    CYA: 80
    Salt: 3100
    Temp: 72
    Filter: Cartridge
    South Central NJ
    3,192
    Re: Unusual white deposits on new plaster..
    It is likely to be calcium given the age. You are in an area where hard water is the norm. We also don't know the mix time used. Is it possible it was hot out too when it was applied? So many variables. All you can do is brush it until it stops.
    Scott
    Owner of - PoolGuyNJ LLC
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by PoolGuyNJ
    Scott
    Thanks Scott. No it was cool.
    We don't know what was in the rainwater from the tank. I should always test all fill water and will from now on but still we had no choice but to use what ever we could get. Yes even with the rain water filling half the pool we used well water to fill the rest. and the CH after was 310.
    So you mean the shell was old and could cause this deposit? The finish we did about 3 months ago. However right away I noticed these deposits. we used freestone diamond brite the owner supplied. He also had his work guys take the old surface off and we just came in to prepare the surface for finish and tiled with their tiles.
    Support the site
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by JamesW
    Yes! Thanks this makes a lot of sense. It took us about 1 week to eventually fill the pool.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    overall I think we did a good job. but we had so much problems getting fill water.
    below a few pics of the pool..
    South Central NJ
    3,192
    The shell didn't cause this.
    That it took a week to fill it and the uncertainty of the water used for mixing did it.
    Scott
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Scott
    Thanks Scott. I figured that. I guess owner will just have to keep brushing until they go away. still only a couple and owner doesn't seem bothered at all. But I was.
    susa's Avatar
    Oct 2010
    Deep South
    578
    In the deep south we use special membrane tanks (think giant scuba tanks) where any type of water source (well, municipal, storage tank) is suitable as it filters the water clear from 90-95% of all the minerals (iron, calcium, etc)
    The cost at fillup is just 100 for the tank rental and well worth the cost in total avoidance of issues at startup.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by susa
    we only have one water truck on the island and its all rusty on the outside...don't know about the inside. but it's $100 for the truck per load and $0.16 per gallon of water. way too costly. most rain water tanks here are either the above ground plastic tanks (which never hold enough water) and the below ground which is concrete and might hold 20,000 gallon if you are lucky to find one that size. and the home owners like to paint them!! so you see the problems we have. The city water is the best bet for filling as it has CH in it. Only problem is sometimes there is algae and rust as well. I need to get one of those metal traps to attach to the hose for filling. I try to start the pool up as soon as possible. I cut skimmers off and run on the main drain to get the water filtered and sanitized. we use drinking water for mixing.
