Results 1 to 10 of 10
Thread: Bow and Arrow Went Through Pool - Help
    May 2009
    Azle, Texas
    24
    My son just shot his bow and arrow and it hit the swimming pool. When through the pool and into the liner. Any suggestions on how to repair the hole in the panel, other than replacing it.
    27 ft round AG, vinyl, 17,100 gallons, 2 HP pump, sand filter
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: Bow and Arrow Went Through Pool - Help
    Isn't it amazing that we all manage to love our own children and very few of us actually kill them before they are grown. Sometimes we want to but to, but we don't!
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by texasdad
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Whereabout on the wall did it pierce the wall? Up high or low? If high, you may want to wait until the pool is open and then from inside the pool, push out the hole and eliminate any jagged edge pushing up against the liner. Patch the liner from the inside and then use an epoxy to patch the pool wall from the outside. Structurally it should be fine.
    Sorry to hear the bad news...surprised my boy has shot a hole through ours yet
    May 2009
    Azle, Texas
    24
    Unfortunately it is in the middle of the wall. Thanks for your advice. Yes the my child is still alive, but barely!!!
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Drain it down, patch the liner, push the sharper parts of the wall out, or trim them, then patch with some scrap plastic (leftover bleach jug cut out?) and patch the liner with a large liner patch.
    Wont be pretty but it will hold just fine.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    22,548
    Or use a thin piece of sheet metal between the liner and the wall held in place by double stick tape or caulking.You could paint the hole to match the wall color and it'll be barely noticable.
    Feb 2012
    Central Indiana
    42
    actuallty since arrows are small diameter relatively.... (hears wheels creaking in head) I used to work at a tire shop when I was a teenager and one of these just might work perfect while protecting the liner from any sharp edges just pull through and snip, maybe put a little silicone behind the head. You would still need to patch your liner but one of these will last a long time. You may be able to buy one from your local tire repair joint. Its called a patch plug and comes in diameters of up to 1/2 inch.
    May 2009
    Azle, Texas
    24
    We are going to drain the pool down and patch the liner. Repair the wall best we can. I really like your idea Bones, we will check will our tire shop. No this won't be pretty but it is cheaper than replacing the panel.
    You should have seen the water pouring/shooting out of the hole, OMG. I thought I was going to have a heart attack. You know how hard you try to keep your pool perfect, crystal clear and baby that little pool. ARGGGG!!!!
    You guys are great!!
    Aug 2007
    near the swamp
    806
    when repairing abg pool walls, I cut out the bad spot, then rivet in galvanized sheet metal or aluminum, then duct tape around or if wall foam is avail then use that
