Thread: New Piping
    Jul 2011
    Plattsburgh, NY
    46
    New Piping
    I'm looking to replace the pipes used on my pool. The previous owners used ABS, which isn't designed to be used under pressure. I'd like to replace it with schedule 40 PVC. Does anyone have any diagrams or pictures of their plumbing so I can get an idea of how to redo it? Currently the pipe has a 90 degree elbow coming out of the skimmer. Then the pipe runs at a 45 degree angle for about 15 feet until it connects to a shut-off. Then it bends 90 degrees and goes into the pump. It exits the pump, bends 90 degrees again, and goes into the filter. After leaving the filter it bends 90 degrees then goes back into the pool.
    My understanding I need to use as few 90's as possible since they restrict flow. However, should the pipe coming out of the skimmer just run at a 45 degree angle, or should it be done another way?
    13,000 gallon ABG with Hayward 1 1/2 HP pump, DE filter, SWG
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: New Piping
    Using 90s isn't such a bad thing in a typical AGP install, as long as you do not have very long runs to the pump. Also remember to use unions (they are your friend when maintenance/winterizing is required )
    Plenty of examples if you search the forum...here is one
    finally-plumbed-my-agp-with-pvc-t20041.html?hilit=hard pipe
