Results 1 to 7 of 7
Thread: Is Arm and Hammer Super Washing Soda the same as baking soda
    Sep 2011
    Atlanta Ga
    310
    Is Arm and Hammer Super Washing Soda the same as baking soda? Is it OK for the pool?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Feb 2012
    Central Indiana
    42
    Re: Is Arm and Hammer Super Washing Soda the same as baking
    no washing soda is Sodium Carbonate(Na2CO3), Baking Soda is Sodium Bicarbonate(CHNaO3).
    22,553
    Washing soda is not the same as baking soda. It is ok for the pool, depending on what needs adjusting. It affects the pH and TA whereas baking soda mostly affects TA.
    You can use the Pool Calc to see what effect adding it will have. There's a section near the bottom on effects of adding chems.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Oct 2011
    New Caney, Texas
    414
    If I read right Washing soda is for raising the Ph and baking Soda for raising TA.
    See this link:http://www.troublefreepool.com/pool-...pool_chemicals
    Edit: Bama and bones got you
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Dec 2009
    Central Massachusetts
    2,690
    No, not the same!
    Washing soda is sodium carbonate. You use it raise the pH. It will also raise the TA as well.
    Baking soda is sodium bicarbonate. It will raise the pH a little on its own, but mainly used to raise the TA.
    The general rule of thumb is to raise the TA with baking soda, and raise the pH with 20 mule team borax (borax rasies the pH, but does little to the TA.
    If you need to do both, you can use washing soda. That being said, you can use the pool calculator to see what effect adding either borax, baking soda or washing soda has on the pH and TA. Generally, you need to add less washing soda to effect a change in pH, but it will alter the TA. FWIW, washing soda or sodium carbonate is the same thing as "pH Up" sold at a pool store.
    EDIT: holy mac, 3 of us at the same time!
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Sep 2011
    Atlanta Ga
    310
    Thank you all.
    27000 gallons
    Pool built in 1971.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    As I mentioned in your other thread...I would use the washing soda (a.k.a. soda ash) to raise both your pH and TA since your CSI is so negative.
