Thread: Compupool vs. Circupool output ratings
    Fairfax Station, VA
    52
    Since Compupool and Circupool use the same cells, shouldn't the output be three same for the same size cell. For instance, Circupool RJ45 and Compupool CPSC 36 use same cell, why are they not rated same output?
    35K gallon plaster IGP, free form, spa with spill-over; Sta-Rite 2HP pump; KDI American 48sq.ft., 144GPM DE filter; Pentair MiniMax heater; pressure side The PoolCleaner; Circupool RJ45
    22,553
    Re: Compupool vs. Circupool output ratings
    The chlorine output is determined as much, or more, by the transformer and controller as by the cell size. By varying the current and voltage to the cell you determine the output of the cell.
