Results 1 to 12 of 12
Thread: pentair Intellitouch- Who has it and what do you think?
    Columbus Ohio
    178
    So, we are planning to install an automation system as well as pergola, but I am leaning towards the Pentair Intellitouch and I have scoured TFP for weeks mainly only finding technical information, which I'll be honest I am not that intuitive in. So what I am really looking for is what you LOVE about the system or what you HATE about the system... as well, what you think would best suite our needs. We have a 16x32 Inground Vinyl pool with two intellibright LED's, 4 Deck Jets, Heat pump, as well we are looking at upgrading to the Pentair VS pump, and the Intellichlor- because we are manual chlorinators right now but love the idea of salt. Our circuit box in the basement is full, so we have no idea if we need the Load Center or the Power center- the distance from the electric panel to the pool pad is only about 7 feet. We know we want wireless... we have iPads, iPhones and such, and I do want a wired panel in the house. We really want total automation, so please give your suggestions. If you don't like the Intellitouch please give why and what you would recommend. Thank you so much in advance!!!
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    Jul 2011
    Broken Arrow, OK (Tulsa)
    293
    Re: pentair Intellitouch- Who has it and what do you think?
    I don't know if you've looked at the Easytouch system, which also works with iOS devices (with the Screenlogic option). I know the Intellitouch system offers more flexibility when it comes to programming, as it can do macros, but for basic automation I'm looking at the Easytouch system myself. An Easytouch 8 system should handle everything you've listed, and, unlike the Intellitouch, it can be controlled directly from the outdoor panel as well as with remote (wired and/or wireless) panels and devices. I'm going to watch this thread as well, as I'm really interested in this.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    Nov 2011
    Moberly,MO
    1,010
    I have sold both systems and am more pleased with the Intellitouch. We have had some programming issues with the Easytouch
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Columbus Ohio
    178
    Thank you for your feedback...
    Columbus Ohio
    178
    So does anybody have any recommendations on which intellitouch we should do?
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    I have the intellitouch I9+3.
    Very pleased with the integration with the heaters, pumps (I have two VS), and lighting.
    I have not "finished" programming mine, but I doubt I ever will stop finagling with it, I am a gadget-y person.
    I like being able to adjust the SWG % from my laptop, wish the complete interface was available from the ipads as well .
    I like the flexibility of the control, and the remote capabilities are really nice. Yesterday halfway through the 8 hour drive home from austin I turned the spa on and started it heating, and when we got home it was hot and ready.
    I have not fully explored all the macro possibility, but it looks fully controllable from the program interface on my laptop.
    Be prepared to spend some $$$. Even doing it myself it was several thousand dollars to get everything and hooked up and installed to working.
    Good luck!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Columbus Ohio
    178
    Lershac- Thank you so much for your feed back- We really don't have much of a budget as we figured it would be quite a bit. Thank you so much for letting me know your personal experience. How are the Valve Actuators? and to use the iphones and ipads you have to have the screen logic correct??
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Yes. Screen logic is required. The actuators are fine... The just.... Work.
    I wish there was a larger capacity for actuators, I would love to have about 14.
    Dec 2010
    San Diego, CA
    1,137
    Alright I have to ask - Lershac what all do you want to control with 14 actuators?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Columbus Ohio
    178
    LOL I would like to know the same thing actually... But I did follow his pool build and it seems like a pretty big system to control.. Personally I only need 2 or 3 haha.
    Dec 2010
    San Diego, CA
    1,137
    I followed his thread too and his pool and spa don't seem to be that crazy feature wise.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    No they are not, but I want to have set points for restricting flow to certain features, control over each return individually on the pool, and a cpl other things, like being able to valve off the air intake on the spa jets. My wife loves bubbles but it turns out I am not much of a fan of them.
    My pool is not complicated plumbing wise at all compared to those with many features like say spillmar.
    Two pumps two heaters and a filter. Only water feature is the deck jets which are non functional ATM. Controlling the individual jets would let me set a cleaning schedule for my Polaris and still get the flow in the rest of the pool I like.
