Thread: Jandy LRZ Heater - Max Temp Question
    I have a new pool and have a question about the Jandy Heater. I have the 400,000 BTU LRZ E model. The max temp that the heater will go to is 104. In the controls for the heater there is an option for water temp differential as well as water temp calibration. Is there a way to change these settings to get the actual temp of the spa greater than the 104 limit? Thanks
    45000 IG unite pool, Jandy DE filter, Jandy LRZ heater, Polaris 280, 1.5 hp Jandy pump
    45000 IG unite pool with Jandy LRZ Heater, Polaris 280, 1.5 HP pump, Jandy DE Filter
    Re: Jandy LRZ Heater - Max Temp Question
    How high do you want to go? Anything over 104 F is not safe.
    Support the site
    Feb 2012
    Central Indiana
    42
    Simply no, (and yes but...) it would require changing internal hi temp sensors voiding your warranty and becoming a potentially lethal device in more ways than one.
    Thank you for your replies - I will leave it as is
