Results 1 to 18 of 18
Thread: Recommended pool robot?
    I just moved to a house with a pool that is surrounded by trees. I'm looking for a pool robot that will be plugged into electrical. I want one that does the following:
    - goes up wall and stairs
    - has a large capacity bag
    - has a well made bag so it doesn't easily fall apart and need to
    be replaced often
    - has easy access to take out the bag and throw it out
    - cost around $1,000 though I'm willing to pay more if necessary
    - has a remote control (only if it is something I need)
    Can anyone recommend any models?
    Thanks!
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Re: Recommended pool robot?
    If you hadn't mentioned the trees, I'd recommend the dolphin first and maybe aquabot second. But robots aren't the best with leaves....you can see threads further down in the forum here that focus on that, I think most people are using the polaris pressure cleaners or some kind of net. It depends on what the normal debris in your pool will be..... I've had good experiences with the dolphin deluxe 5, and you can get one from a local pool store normally...the deluxe 4 is closer to the price range youmention, deluxe 5 isn't that more -- it does a thorough job and even gets to most of the stairs and has a remote and caddy included by default. But make sure you understand what type of debris is going in your pool....this is most important determinant of which solution will work best.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    Aug 2010
    Dallas, TX
    4,052
    Agreed. Robots aren't best for leaves. My Dolphin does a great job on everything else, but not leaves.
    Hi MattM and RobbieH,
    If robots are not good with leaves, than what are they good at? I mainly want one because my pool gets lots of leaves, that is the main debris in the pool. I was hoping for a robot that would do all of the work. Right now I have a pool guy cleaning the pool and right after he leaves there are more leaves in the pool. I was hoping to replace the pool guy with a robot and I would take over the chemicals.
    Thanks.
    Nov 2010
    Calera, Al
    271
    I have a Polaris 280 and it sucks! But in a good way! It does a great job and has sucked up everything from frogs, to leaves, to my sock with cya in it, all the way down to little worms and smaller debris. But it is a pressure side cleaner and requires a booster.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I have a smartkleen nitro. I believe they offer a wall climber model with a remote. It's pricey. I've got the base model and been pretty happy with it.
    Here's a link to the manufacturer. http://www.smartpool.com/website/cleaners.html
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Some of us are lucky not to have any leaves in our pool When my dolphin runs, it scrubs the tiles, gets to the stairs, gets all the dirt and dust, if there are a few small leaves in the pool - it will get that and leave the pool almost spotless...but the bag and suction from what I can isn't designed for a huge amount of debris or large items like leaves. Different environments have different needs.
    Is there any device that is designed for leaves?
    30,419
    Well, yes, a leaf rake. That answer isn't intended to be as smart-***** as it may sound.
    The entire issue with leaves is mass. If you get 30 leaves a day, a robot will pick them up without issue. If you get 300 leaves a day, most cleaners of all types will begin to struggle handling that much mass. If you get 3,000 leaves a day like I do in the fall, there is no machine made that will have the capacity to get them out of your pool......hence the leaf rake.
    So if your looking for something to get out just a few leaves, most cleaners can deal with it. If you have a lot of leaves, the machines won't cut it.
    Apr 2011
    Murrieta, CA
    2,360
    I get leaves and so far so good. Not big leaves from a maple tree type leaves but leaves from an oak tree and hedge trees. But the suction ports measure about 1 inch by 1 inch and 4 inches wide or so by 1 inch tall. .
    Oct 2007
    Parkland, FL
    752
    robots are cool, but most don't work that well, the best out there is the blue diamond IMHO, plus it has a good warranty, warranty is really only thing that matters because you will use it. my blue diamond will pick up leaves, it will pick up pretty much anything when it works. IMHO you buy a robot because its really cool and you are a geek. Otherwise its probably cheaper to just have a pool guy come. as for cleaning, they do clean well. when mine works, it does an excellent job. I wouldn't worry about it climbing the walls. mine climbs , i've had 3 different types and none of them do that great on the walls. maybe its different in other places but my walls don't really get dirty anyway.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    My Aquabot does great with everything, including leaves.
    Julie
    I have a small (3,750 gallon) in-ground, Viking pool - 2hp Jandy pump, AquaPure 700 Cholorinator, Jandy Aqualink, and Jandy CJ250 filter
    kenandshari's Avatar
    Aug 2010
    Savannah, GA
    134
    We have a Smart Pool Nitro Wall Climber (model NC-51) and it does a phenomenal job at getting leaves, pine needles, and acorns from the bottom of the pool. The bag is sturdy and holds a lot of debris. It climbs the walls and is electric. We did not spend extra for a remote controlled model, just the regular plug in and turn on model. They cost well under $1k and do a great job. Today we mowed the yard for the first time this year and we rinsed all the grass clippings off the solar cover (and into the pool) as we removed it adding to the mess. This time of year here leaves are blowing into the pool from the oaks at a record pace and there were a lot of leaves on the bottom of the pool. In one 3 hour period our Nitro cleaned up about 90% of the leaves. We'll run him again in the morning and probably have the pool ready for the kids to swim by noon. (Solar heater has the water up to 72 now!) The bag is a bit larger than a gallon milk jug and it has a really tight weave that even catches sand and a lot of pollen. When I emptied it this evening it was about 3/4 full of densley packed wet leaves. Cleaning is eaasy enough too. Dump the bag and hose it out, then snap it back in place. There's youtube videos by Smart Pool that show it in action if you want to check it out.
    On the down side, We did have to send ours in for repair two times but they covered it all under warranty both times and even covered the return shipping. The second time they sent us a different same model Nitro. We actually bought ours from Smart Pool as a factory refurbisned model for a deep discount off the new price. The replacement Nitro has been running fine ever sine July 2011. We use about 4-5 times a week in the summer and about once a week when it's not swimming season and it keeps out pool looking really good. Every part is available to rebuild it and all you really need to do it is a screwdriver. They even have videos online that show you how to replace everything for total DIY repairs after the warranty period. I don't work for the Smart Pool (I'm not even in the pool industry) and receive nothing for recommending the Nitro. We're just really pleased that ours does a great job and the company stands behind their product. I can't speak for longevity as we've only had ours a little over a year now, but if it lasts as expected then when it finally is time to replace it I plan to get another Nitro. Whatever you choose, best of luck to you in your search for a robot.
    Ken & Shari
    Savannah, GA
    16' x 40' freeform fiberglass inground (Pacific model, mfg by Tallman Pools), 23k gal, 2" plumbing throughout, Intellichlor IC-40, Easy Touch controller, Intelliflow VS 3050 pump, Pentair Clean & Clear Plus Quad Cartridge filter. 4 Jandy deck jets (3/4" plumbing), Fiberstars color changing lighting, SR Smith salt friendly diving system, Interfab Wild Ride slide, Aquasol Solar Heat (5 panels 4'x12' DIY install automated with ET) RIP Nitro Wall Climber Mar 2011-Aug 2012, Nitro is survived by a Polaris 360.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    I too have the Nitro. Ours seems to be very temperamental. When it works it picks up almost everything....but nothing ticks me off more than when it's heading right towards the group of leaves, then makes a u-turn right before the problem area! Lmao!
    Guess I'm the small group who should have picked the remote.
    Mar 2012
    Cincinnati, OH
    57
    Bellbound, Did you make a selection on a robotic pool cleaner? I too am looking for one under a $1,000.
    18k, 2001 Ft. Wayne 18'x36' oval sport pool with polymer walls, IG, vinyl, 3.5' at ends and 5' in center, Pentair 1 1/2 hp 2-speed pump (new in 2014), Pentair Clean and Clear Plus Cartridge Filter (new in 2015), Pentair IntelliChlor IC40 (new in 2016), new Raypak RP2100 propane heater (installed 4/2013), Mayfair Dolphin Supreme 4 cleaner, 3 jets, 1 floor drain, 1 Polaris jet (never used), 2 skimmers, new Garrett liner (installed 4/2012)
    I'm curious too. Do you have a plaster pool? Is a robot recommended for plaster?
    In-Ground 12000 Gallon Pool/Plaster Walls/Hayward S244T Sand Filter/Chlorine/1.5 HP pump
    Phoenix, AZ
    30,419
    Not specifically. Any of the three types of cleaners (vacuum, pressure or robot) can be used in most any pool surface.
    Even though this is a generalization, you pay for cleaning power.. The larger pool you have, the more cleaning power you need.
    Also a generalization, but you will pay more money for more cleaning power.
    Sep 2010
    Orange County, CA
    52
    I've been using a Dolphin for a few years and it works pretty well. I used to have a suction-side cleaner, but my debris kept breaking things in it, and it was a new $30 part each time. That gold old, so I decided to get a robot due to the larger openings. My debris is small pine needles, pine cone fragments (which broke the part in my old suction-side cleaner), leaves, and dirt. It works pretty well and I've been pretty happy.
    My Dolphin died recently (well out of warranty). The cleaner was working but the power supply died. Since the power supply was half the cost of a new one, I decided to buy a new unit. I got a Dolphin Premier. So far it's working well. I've only had it a few weeks.
    As others have mentioned, the bag capacity is limited on these things. When I get a lot in the pool from winds, etc., I try to remove much of the bulk before putting in the robot.
    Southern CA 30K gal Pebble Pentair WhisperFlo 1HP 2 speed Hayward DE6020 filter Paramount Debris Canister Goldline/Hayward AquaRite Pro SWG (T-CELL 15) Sense & Dispense (acid) Pentair IntelliBrite 5G and GloBrite Inter-Fab G-Force slide Jandy deck jets Lion head spout Dolphin Premier Cleaner Taylor K-2006 test kit
