Thread: Recent plaster discoloration...
    Feb 2012
    Fort Worth, Texas
    2
    To whom it may concern:
    I have recently taken over the care of my pool. Over the past few months I have noticed that my pool plaster has begun to dis-color. It seems to be an equal balance of blue’s and grey’s now.
    Pool History...We purchased the house with the pool about 5 months ago. The pool had not been serviced for some time and the water was stagnate and it had black algae. We had the pool drained and pressure washed. Once refilled the pool looked great. The black algae retuned not too long after it was re-filled. The pool was shocked. It stopped the black algae for a while and then it returned for a 3rd time. The pool again was shocked and it has not returned since. It seems the plaster dis-coloration became more obvious as the water temp got colder with the onset of winter. We live in Texas and the average water temp this winter has been between 45 and 55 degree’s.
    Can you please give me some thoughts and possible remedies to fix the issue. I have pictures I can sent too if necessary.
    Thank you, Dan
    Approx. 6,000 Gallon Pool
    System 3 Catridge filters (qty of 2)
    In ground Pool
    Plaster Finish
    Pump- Pentair IntelliFlow-VS-SVRS
    Filter MAX Flow Rate-125 GPM
    30,403
    Re: Recent plaster discoloration...
    Hi, Dan,
    Welcome to the forum. The pictures will help a lot so please post them.
    What will help even more is a set of current test results. The forum almost begins and ends with accurate testing of your water because almost every issue with the quality of swimming pool water is due to some parameter being out of whack.
    Post CURRENT results for .....
    FC
    TC
    pH
    TA
    CH
    CYA
    Those abbreviations are found in an article in Pool School in the upper right hand corner of the page if you are not familiar with them.
    Feb 2012
    Fort Worth, Texas
    2
    Thank you. I appreciate the advise on the water testing. I will test it asap and get back to you on that. In the meantime I have attacehd a couple of pictures.
    Attached Files Attached Files
    In ground Pool
    Plaster Finish
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: New to "Trouble Free Pool" with a question...
    Sounds a lot like metal staining. Are you using an ionizer or a copper based algaecide?
    Oct 2011
    New Caney, Texas
    414
    Hi dpinch and welcome to the forum.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Those pictures look familiar!
    Sure looks like Calcium scale to me. Mine tends to look blue-grey when submerged, and a pale tan color when exposed.
    Let me start with the TFP Mantara: Can you post a full set of test results?
    [center:6xl32vr3][/center:6xl32vr3]
