Thread: What is this jet/fountain for? Are their attachments?
    Dec 2011
    Naples, FL
    40
    Hello
    I was wondering if anyone knew of something that screws on to this or some type of attachment that creates a fountain or an actual water feature, or if not, then what it can be used for? The jet itself is pretty much the same as all the return jets in the pool it just is in a weird place. It is labeled water feature at the valve but to me it seems like something else should be there. Maybe I'm wrong and this is all its supposed to do.
    The house was a foreclosure so we do not know if somethin is missing or if that's all it does.
    Thanks!
    Pool: ~11,500 Gallon Free Form, In Ground, Plaster, 23x17 with raised Spa and SunGrabber Solar
    Pump: STA RITE Dyna Glass MPF series 1.5 HP
    Filter: Cartridge Pro Clean PCCF-100
    Jul 2011
    Broken Arrow, OK (Tulsa)
    294
    Re: What is this jet/fountain for? Are their attachments?
    Looks like a bubbler to me. We've got one on our tanning ledge as well. On ours, the height of the water is controlled by the valve opening at the equipment pad.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    Dec 2011
    Naples, FL
    40
    Ya I can turn the valve all the way open and close the other return lines it gets as high as it is in that photo, and if I open the other lines too, then it only breaks the surface by a few inches.
    I was hoping some kind of cool water feature hooked up to that but sounds like it is a bubbler. So what is the purpose of a bubbler then?
    Jul 2011
    294
    Although some may chime in here with water "tech speak" about the benefits of aerating the water, for us the benefit is that the little ones will really enjoy playing with the water as it bubbles out of the pool. LOL....I guess, if you placed a chair over it just right, it could also serve as a seat cooler. We all love the sound of the bubbling water.
    Apr 2017
    Manorville, NY
    6
    Are you sure that this isn't for a self-cleaning floor jet of some sort?
    Quote Originally Posted by SWFLNICK View Post
    Hello
    Thanks!
