Results 1 to 7 of 7
Thread: Question on Replastering
    Dec 2011
    Charleston, SC
    100
    A plasterer is quoting me a straight replaster without the following:
    no new extended pluming on return fittings and equalizer lines
    no new white goods (return fittings, vgb main drains, equalizer grates)
    If I do not get these above items...Will my pool still function fine?
    Bear in mind this pool was a acquisition with a short sale and I have never had a pool, so I am new at this. I plan on hiring someone to treat the pool for the first three months so I can learn from them and I will not screw up the plaster.
    IG Gunnite Pool Size: 25K gallons (20 x 40, 3'6" to 6" depth) with 2 huge Baker Hydro cartridge filters under the skimmer baskets on the suction side, 2 mech timers
    BRAND NEW PLASTER! Quartzscapes/Diamondbrite, Newer Polaris 280, Brand New Hayward Maxflo VS, Brand New Pentair Intelichlor
    I will conquer the black algae this pool season!!!
    South Central NJ
    3,192
    Re: Question on Replastering
    Return areas are chipped back. No need to extend.
    Drain covers must be replaced. If he doesn't, he is in violation of the law. He knows this. He may not charge for it. Drain covers and any other white goods should always be replaced when replastering. I always have, my previous employers always have.... I never heard of it not being done.
    Scott
    Owner of - PoolGuyNJ LLC
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    All of my VGB drain grates say replace every 7 years.
    I would replace em. Its not like any of it is expensive! I bought my complete white goods package for less than $500 including the skimmers (which you wont be replacing)
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Aug 2010
    Dallas, TX
    4,052
    Depending on the pool service you hire, you may or may not learn anything useful from them. I've seen some that use liquid chlorine, and I've seen some that chlorinate via trichlor pucks in a skimmer. One of those is not the correct way to do it!
    The company I talked to about replastering my pool offered a service to maintain the plaster for me for a month so I didn't have to worry about it. It basically was maintaining the pH and doing the needed sweeping. You might ask your guy about something similar. I can't say if it was worthwhile, I can't replaster because we are on stage 3 water restrictions which forbids draining and refilling pools.
    Feb 2012
    Canoga Park, CA
    6
    Hi scott,
    why would you have to replace the drain covers??? Im new to this....BTW. I just bought a house and I have to get my pool replastered too. Is it semi- easy to do it yourself?
    Quote Originally Posted by PoolGuyNJ
    Scott
    Aug 2007
    near the swamp
    806
    it's a safety issue, called the Virginia Graeme Baker Pool & Spa Safety Act
    South Central NJ
    3,192
    Replastering in not a DIY project. There are a number of skills that need to be mastered for prep, mixing, applying, and finishing.
