Thread: Stains for leaves
    Stains for leaves
    I have an 18,000 gallon white plaster pool that I have teaken care of for the last 4 years. The pool came with the house and it was a foreclosure so I dont know how old the pool is but it does need replastering. Last fall a lot of leaves accumulated in the pool as well as other organic stuff (I have a "fruitless" pear tree that hangs over the edge of the pool at it dumps all kinds of very small pears) that I couldnt get cleaned up for some time and now that I've cleaned the pool there are permanent stains. Brown stains to be exact. What do I do about the stains?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Stains for leaves
    After winter, I usually have quite of few leaf stains on the bottom of the pool and they usually fade over time and are gone by swim season but shocking helps speed up the process some.
    Mark
