Results 1 to 7 of 7
Thread: New pool owner in San Diego
    Mar 2008
    San Diego, CA
    2
    Great forum!
    New here. Became an overnight pool owner when I bought the house about a year ago. I had no idea what I was doing so I used the Internet, downloaded the filter manuals, and learned how things operated. My first project was to remove the 30 ft trees that were less than 1 ft from the pool deck. I was concerned about the roots becoming invasive and this also helped keep the pool 100% cleaner. I noticed my DE filter was always above pressure, so cleaned that, and install a leafcatcher and strainer filter and that has kept the pressure constant ever since. I also have a Golden Retriever who uses the pool more than us, and this has kept his hair from entering the system. Unfortunately, the pump ran dry one day for reasons unknown, got the intake and return lines super hot and I think shrunk them. Now I have a slight leak on the return and I'm sure a small leak on the intake. My next project is to replace the intake and return lines, and put in quick connects for the pump system (pentair). I'm almost positive my pump is overrated for the pool (2HP), but it is what it is. After the pump project, I"ll need to replace the caulk between the coping and the deck. From what I read, pack it with silica sand, and Deck O Seal it up. Some of the tiles along the pool are falling off, the pool surface is stained, but the 5 year plan is to remove that and redo the entire deck/pool.
    As for the things I'm doing wrong, well probably the water analysis. I keep my inline chlorinator full with tablets at all times, but honestly never test the water. I'm hoping to learn from the pro's here how to better manage this.
    I'm glad I was able to find this site. I'm sure I feel like most pool owners, where I feel pride and ownership in having a nicely running pool. Now if I can only keep my dog out of it!
    Thanks all for letting me aboard!
    T
    27' Round AGP, 17200 GAL, 2 HP/2 SPD Pump/Cartridge Filter.......BBB!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Welcome! The dog looks like it loves it.
    Well, for admittedly not know what you are doing, your pool and water looks really good!
    If you start reading "the stickies" (linked in my signature) you will soon learn all you care to know (and sometimes more!) about keeping a beautiful and safe pool!
    You are in the PERFECT place to learn about proper water balancing and maintenacnce, and folks will probably even chime in about your restoration plans!
    Welcome to TFP, to you and your pooch!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    30,432
    Welcome to the forum....glad you found it.
    You might consider a "backer rod" rather than sand. It's essentially a cheap, round rope of foam plastic that you simply push down into the crack far enough below the surface to allow the caulk to be formed on top of it. Comes in a variety of diameters and really easy to deal with.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Welcome to TFP! Again, looks like you have done a pretty good job for being thrown in the deep end so-to-speak.
    A quality kit should be your first priority. Dave (duraleigh) doesn't toot his own horn much, but if you look at the link in his signature above, you'll see a link to www.tftestkits.com. Dave is the owner and makes the best residential test kit on the market.
    Again, welcome to the site and be sure to post any questions you come up with.
    Sean
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Mar 2008
    San Diego, CA
    2
    SeanB,
    Thanks for the welcome and heads up about the kit. I've got plenty to read and this site almost seems to cover almost all of the topics!
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome Triumph
    Your dog looks like he is having a great time! Pool and water look wonderful!
    Joyce
    You're done SLAMing when:
