Thread: Is "Spa" a hotter setting than "pool" mode on heat pumps?
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Just curious as we have a 110,000 BTU Heat Pro on a 16,000 gallon pool.
    The water temp right now in unheated pools is 69F. This heat pump has the water at 87F but owner wants the temp to be 91F but we are having problems getting up there. The heat pump is not exposed to sunlight and is in a shaded area which I think makes a difference. We run the heater 23 3/4 hrs per day. almost 24/7 but still can't get the temp up. This is the first time since we installed it we had this problem. Right now the air temp is 79F but this weekend it was much lower in the 60's.
    I have switched over to spa mode hoping this will help.
    anyone can spread some light on this? Many thanks!
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Is "Spa" a hotter setting than "pool" mode on heat pumps
    Spa mode is not "hotter" than pool mode... the heat pump puts out the same BTUs either way.
    You may want to have the heat pump serviced to make sure it is functioning correctly (correct amount of refrigerant etc)
    The main way pools lose heat is through evaporation... consider putting a bubble-type cover on to stop the evaporation. It makes all the difference in the world to my installation. Without it my heat pump cant keep up, but with it it can.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by Lershac
    Thanks for the reply. This heat pump is only a few months old. We are working on finding an a/c repair person. They might be able to service these heat pumps as they are basically a/c's working backwards to heat instead of cool. We don't have a pool cover but that's a great suggestion but owner would want a roll type pvc cover. expensive and finding someone here on the island who can install one will be a challenge. I've read raising the temp up might help so will go back to pool mode and increase desired temp to max.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    When the heat pump is on... it puts out the max BTUs it can until it cuts off... if its running constantly thats the max its going to put out.
    Sorry to be the bearer of bad news.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    I think if we went with the 140,000 btu one we might have been ok. but definitely a pool blanket is a great idea.
