Thread: Are the different types of Sight Glass all the same?
    I'm going to replace the sight glass on my sand filter because it's become really discolored. I've been searching on-line, but I'm not sure why some of these units are so $$$! Will i regret buying a cheaper one? I've found some on amazon ( http://www.amazon.com/Hayward--Line-Sig ... 69&sr=1-16 ) for around $30, but I've seen some close to $100. What's the difference? Why would someone pay so much for a different type?
    GTGallop's Avatar
    Aug 2008
    Cave Creek, AZ
    39
    Re: Are the different types of Sight Glass all the same?
    is the glass discolored or is it something like a buildup? Could you clean it with bleach or CLR?
    3rd Time Pool Owner - 2014 In Ground, Gunite/Pebbel-Tec, 24' long 10,000 Gallon, Chlorine, 2 Hp Hayward Ecostar with Cartridge.
    http://www.troublefreepool.com/my-on...le-t40734.html
    Cave Creek, Arizona
    No, its no longer clear from the sun. It has to be replaced - its not buildup or anything that can he removed.
    Aug 2011
    Metro Atlanta, Georgia
    161
    19.99 on fleabay.
    If the glass is clear plexi glass, you can use polish from your local autoparts store, which will take care of most discoloring and scratches (you can also mix cigarette ashes with foam shaving cream, not the jell and polish with that).
    I am a bit confused, because most glass made today does not discolor in the sun, so I am guessing the glass is made of plastic
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    22,542
    Here are some clear PVC sight glasses. I'd try these first.
