Thread: Freeze guard, can I bypass it??
    Aug 2011
    Fort Worth, TX
    32
    Wife and I were enjoying the spa last night with the snowflakes dropping ever so lightly... Enjoying some 90+ temps then the freeze guard kicked on!!!!
    I'm wondering if there is a way to bypass it, at least while we're in there. I know it's there for a reason, but so am I!
    Please let me know if that can be done.
    TYIA
    23x34' IG freeform play pool (18,850 gallon) ~ 7' spa raised 18" with 6 jets and 5 tier waterfall ~ IntelliChlor SCG ~ Pentair Intelligent VS-3050 variable speed pump ~ Clean and Clear 420 cartridge filter ~ Easy touch controller ~ Blue Granite Pebble Sheen ~ Intellibrite LEDs ~ Turbo twister slide ~ 8x8 flagstone tanning ledge with umbrella sleeve and bubbler ~ In-pool flagstone table with umbrella sleeve ~ 947 sq ft exposed aggregate decking
    Feb 2012
    Phoenix, AZ
    728
    Re: Freeze guard, can I bypass it??
    Is your spa running off of the equipment listed in your signature box? Or is your spa a portable above ground unit?
    Normally you would not want to disable or bypass the freeze guard. Can you simply turn off the pump while you are using the spa?
    Aug 2011
    Fort Worth, TX
    32
    The spa is connected to the pool equipment. Not sure if I could turn the pump off... Wouldn't that make the water cycling through the heater to stop too?
    22,551
    You can turn freeze protection on or off in the programming but I'm not sure it's worth the trouble for one time.
