Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 86
Thread: Our dig began today!
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    So glad to finally see the work begin. Although it has unfortunately turned very cold and does not feel anything like pool time.
    I'll update pics as the work progresses each day.
    Sent From My Inspire 4G Using Tapatalk
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Our dig began today!
    Good deal!
    Jan 2012
    West KY
    243
    Finished with todays dig. Should be forming tomorrow. Will post pics again once walls are up.
    TF100 Test Kit
    SpeedStir
    Jan 2012
    West KY
    243
    [attachment=0:3cnmbkbl]uploadfromtaptalk1329169702198.jpg[/attachment:3cnmbkbl]
    TF100 Test Kit
    SpeedStir
    Jan 2012
    West KY
    243
    Started on forms for walls yesterday. Unfortunately it warmed up and rained so now our yard is a rutted mess where they drove in and out
    TF100 Test Kit
    SpeedStir
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Looking good!
    Jan 2012
    West KY
    243
    Question about backfill. I mostly see recommendations of gravel. Our PB says he only uses dirt now. Says he's only had 2 liners to float on him and both were on pools backfilled with gravel. However, they are installing gravel and a French drain. Our pool is at the bottom of a very slight hill directly behind our house and will be completely surrounded by concrete decking between it and the house.
    Should I demand gravel, or is it not a deal breaker?
    TF100 Test Kit
    SpeedStir
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Liner issues are not behind the recommendations for gravel over dirt fill. Settling is. Gravel will tend to self-compact with little settling. Dirt will settle like mad unless it's applied in small lifts and compacted between lifts mechanically....and even then it may settle.
    You want that concrete deck (likely the single most expensive part of your build ) to last a long time without settling, separation and cracking, then go with gravel backfill.
    Just my .02$
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Jan 2012
    West KY
    243
    Thanks. I'll definitely be having this discussion with the builder because we are doing quite a bit of concrete decking.
    TF100 Test Kit
    SpeedStir
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by Lershac
    Just my .02$
    I guess I read here if using dirt you should wait a year before pouring even if you compacted it so it can naturally settle. Under my deck was all 3/4" drain rock, approx 12" to 24" thick.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Jan 2012
    West KY
    243
    Skimmers, rebar, and some plumbing runs today. They hope to finish the forms and bring in the pump truck to pour the walls tomorrow.
    TF100 Test Kit
    SpeedStir
    I have seen dirt settle almost 12-16 inches...gravel for sure.
    Jan 2012
    West KY
    243
    Stairs in, walls poured today. What a muddy mess it is though. Still, we have progress!
    TF100 Test Kit
    SpeedStir
    Jan 2012
    West KY
    243
    Forms off walls, started plumbing and setting forms for cantilevered coping today. Should have coping finished tomorrow.
    TF100 Test Kit
    SpeedStir
    Feb 2012
    Phoenix, AZ
    728
    Looking great! I can't wait to see more pictures and watch your progress!
    Jan 2012
    West KY
    243
    Thanks. They hope to get the coping poured tomorrow and maybe complete the waterfall. I'll try to get some more pics up when I get home tomorrow afternoon.
    TF100 Test Kit
    SpeedStir
    Jan 2012
    NJ
    25
    Nice to see your progress and looking forward to following your thread!. We just signed for a concrete wall liner pool last weekend, build prob start in May.
    Jan 2012
    West KY
    243
    We have water going in
    Still so much work to do, but by gosh it looks like a pool now!
    TF100 Test Kit
    SpeedStir
    Oct 2009
    3,899
    congratulations! Time for a quick swim, no?
  20. Back To Top    #20
    Jan 2012
    West KY
    243
    Quote Originally Posted by Melt In The Sun
    I'll have to pass on the swim for now. Haven't checked water temp, but it can't be over 50F
    TF100 Test Kit
    SpeedStir
