Results 1 to 18 of 18
Thread: Polaris 280 tail sweep inop
    Feb 2012
    North Texas
    19
    The tail sweep on my 280 does not move from side to side, it just drags straight behind the unit. The cleaner moves along the bottom, climbs the wall, etc. There is no blockage in the cleaner, hoses, or back-up valve. There is no pressure loss at the wall fitting or releif valve. The tail sweep adjustment screw is turned counter-clockwise about as far as it will go without falling out. The pump strainer basket is clean. The cartridge filters are clean. I have added no additional weights to the tail. What am I missing? Any help is greatly appreciated.
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Polaris 280 tail sweep inop
    check the tail sweep hose for any hole caused from wear. check the orfice at the end of the tail sweep hose to be sure it is not worn or pluged.
    Feb 2012
    North Texas
    19
    No holes in the sweep hose, not plugged or damaged in any way. Is there a pressure gauge that can be used to check the pump pressure at the wall fitting and if so what should the pressure be?
    Open up the cleaner and check the water management system for obstructions. It can happen often if you have small debris. Debris will get caught inside the cleaner and can plug up certain parts of your water management system.
    Feb 2012
    North Texas
    19
    I have completly dis-assembled the cleaner looking for debris, bad o-rings etc. Everything looks ok. No obstructions in any orifice, water sprays hard out of the tail scrubber end but the hose does not move side to side.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    when mine did that it drove me crazy, until I noticed the sponge on the end was protruding past the end of the hose. Once I made sure a little bit of the hose was poking out the far end of the scrubby sponge it sweeps as I would expect now.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Feb 2012
    North Texas
    19
    The scrubber was sticking past the end of the hose by approx. 1/4 in. I moved it flush with the end but still no sweeping action. Maybe the cold water is making the sweep hose to stiff to sweep?
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    If you pull the tail out of the pool, how far is it shooting the water?
    Feb 2012
    North Texas
    19
    Holding the hose level (horizontal) approx. 20 feet.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    oh wow... then its definitely putting out the pressure... No idea then. Whats your water temp?
    Feb 2012
    North Texas
    19
    Today, pool water temp is 51 degrees.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Maybe it is too cold? Is your Polaris going really fast around the pool?
    Feb 2012
    North Texas
    19
    No faster than usual. Pretty much same speed as always.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    With water that cold, I bet the tail is just too stiff. I would try not to worry about it, and wait til the water warms up to see if it starts flailing again.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Heat the pool up just to see?
    great thread guys, the comments here saved me and my polaris is happy again
    Pearland, TX build ongoing. Freeform pool with Spa. Estimate finish 1st week March, 2014
    Dimensions 37 x 24 x 17 feet. Spa is 8ft round. Approx. 20,000 gallons.
    Variable speed Jandy pump, Jandy Cartridge filter. Aqua pure salt water system. Polaris 280 (black) 3 LED Lights: 2 pool, one Spa.
    Pebblesheen. Blue Granite. Travertine decking and coping.
    Nov 2013
    Fort Worth, TX
    114
    I had the same issue when I purchased a house. I don't know how old the hose was, but it became inflexible over time. I purchased a new hose and that solved the problem. The new hose was much more flexible.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    Some time back I asked the manufacturer about operating my 280 in cooler water temps. This was the response;
    It's recommended for the cleaner to run in water no cooler than 65 degrees F. This is because the hoses can become firm with cold water and will dictate the path of the cleaner. Have a great day, Sir.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
