Thread: waterway eyeball fittings
    We had our pool redone after 34 years and the Eyeball fittings they installed won't rotate. They are made by Waterway and are in the color of dark grey. Out older ones moved easily to change the water flow direction for the Zodiac Cleaner. My question is does anyone know if they make these fittings that do not freely so you can change the flow or are new pieces just stiff and hard to move?
    20000 Gal
    IG
    Gunite
    Intelliflow Pump @ 2000 RPM
    22,543
    Re: waterway eyeball fittings
    My eyeball is very hard to move but it does move. Are they bolted on or screw in (does the face have screws or does the whole fitting thread into the return?
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    If they are waterway I think they are the screw in kind. It might be a good idea to loosen the with a wrench and the pump off, and apply a little lube, then tighten them lightly with the pump on - hand tight only.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Mar 2011
    441
    Quote Originally Posted by Lershac
    I typically grab a long handled screwdriver and use that for leverage.
    20X40 30,000 gallon gunite pool
