Thread: Vermiculite math - Downunder.
    Jan 2012
    Kalgoorlie - Western Australia
    27
    Hello.
    We are putting in a small AGP (inground) and I am finding it a little difficult to get an idea on our vermiculite requirements. Pretty much all the examples are in imperial and it's been 20 something years since I attended school .
    The pool is a Lap shape and is 5.2m by 3.0m - uniform depth. For 2 inches (5cm) I get as follows.
    300x520x5 = 780000cm
    Divide by 1000 to get litres
    780 litres
    Divide by 100 (100 litre bags) gives me approx 8 100 litre bags.
    Am I on the right track. I know that the cement will take volume but I have no idea what happens to the volume of everything when mixed. The problem for me is that I cannot buy it locally so I need to pick it up when I visit the nearest city. I have found a PDF that suggests a 1 to 6-7 type ratio (cement - vermiculite).
    Any help would be appreciated.
    7400 gallon, IG vinyl, .75HP, Cartridge, Zodiac Chlor Perfect chlorinator. Almost finished building :)
    22,550
    Re: Vermiculite math - Downunder.
    Your math is correct. I get 700 liters for a oval pool and 800 liters for a rectangular pool. If you're mixing at a 1:6 ratio you'll need 8 bags of verm and 200 liters of cement. I'd buy 10 bags of verm and 400 liters of cement just to be safe.
    Jan 2012
    27
    Thank you for your response.
    I have spoken to the two suppliers we are looking at purchasing from and they both suggest sand only as a base. I think it is not all that common to use this type of mix down here in Australia. Most of the installs I see on the net are the large bolt together steel wall with deep end type pool (not available here ) but I presume this mix is ok for the standard above ground pool install? My partner installed one a few years back with sand and she made the comment that even though they compacted they still had movement underneath and I really want to avoid that as this pool will be buried with decking and I would hate to have to go back.
    Regards Duncan
    22,550
    Sand is the common base but since you're burying it Verm might be a better option.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!! Mate!
    Please check out this and let me know if you need more assistance
    Luv& Luk
    -Ted
