Results 1 to 10 of 10
Thread: Check Valve problem
    Check Valve problem
    I have a pool and spa and when I went out this morning the spa was completely empty. How do I know what vale and where it is to try and fix it. I have drawn a diagram of the layout of all the equipment and plumbing. I do not know how to trouble shoot the problem and also how to repair it.
    Any help would be great.
    Thanks
    JJ
    Mar 2011
    Hazelton, PA
    57
    Re: Check Valve problem
    Take a picture of your equipment and post.
    22,551
    Ditto on the pics. That will help figure out how it's plumbed.
    I will take picture tomorrow and post it.
    Thanks
    JJ
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    In any event, you are draining the water out of the spa, yet not returning it TO the spa... so 1 of two things...
    1. your spa returns are off or restricted too much. the water is being pumped out faster than it can accumulate. So make sure all your pressure side valves are open and watch the spa returns to make sure there is water coming out.
    2. Your pool drain is off, and all water is being drawn from the spa and returned to both the spa and the pool, which will empty your spa. Make sure all your suction valves are open!
    or some combination of the two... do you have automation?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Yes I have automation and the problem only happens when extremely cold out.
    22,551
    If it's only happening when it's extremely cold it may be the freeze protection opening all the valves draining the spa. I'd check that.
    How do I check that??
    Thanks
    22,551
    You can start by checking what all is on the freeze protection circuit in the programming.
    Thanks I will check it out.
