Thread: solar cover vs solar sun discs
    I am going to be having a 16x32 rectangle pool installed in Pennsylvania. The poolbuilder offered 2 options a solar cover or sun discs. Since i never had either, I was wondering what some opinions on the 2 different covers were
    Simply, we find, hire and train the most talented individuals possible and we work hard to keep them.
    Autoform
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: solar cover vs solar sun discs
    Any type of solar cover serves 1 main purpose
    to prevent evaporation (pool lose A LOT of heat via evaporation)
    So a solid pool cover does a better job at this.
    Solar discs are not a lot of help.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Dec 2010
    San Diego, CA
    1,137
    Solar disks also tend to bunch up at one end of the pool if you have wind. Go with the solar blanket and cut it in half if you don't use a roller
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    thank you, all this input is a major factor in helping us out before we sign our contract.
    Thanks
    Wheelman
    Autoform
