Results 1 to 11 of 11
Thread: my brothers sand filter
    Feb 2011
    Petaluma, Ca
    665
    My brother is buying a house with a intex pool with I think a sand filter. I'll get a pic today to help figure out what kind. There is one intake from the pool, one hose to waste, and one return back to the pool. There is a valve on the top with various positions, Filter, filter to waste, backwash, backwash to waste, there are a couple more I cant remember at the moment. Turning it will send water out the waste line but it is always clean. I have a feeling the sand may be channeled. Around the valve there are approx 6 bolts holding it on, there are approx 25 around the canister holding the two halvs together. To see inside would you remove the 6 bolts? Were going by there today and I wanted to help him get it filtering. If this description is too lame I'll have better info tonight to clarify things.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: my brothers sand filter
    You want the joint with 6 bolts, that should take off the valve. Take a look at this for the channeled sand issue: http://www.troublefreepool.com/my-sa...-it-t7626.html
    Feb 2011
    Petaluma, Ca
    665
    Thank you, I was hoping that it wasn't the 25 bolts.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Does the water come out clean out the waste line no matter what setting? Because it will come out clean out of the waste line when set to filter to waste/rinse, and waste. It will usually only come out dirty on backwash since that is the self-cleaning setting.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by X-PertPool
    Thanks for the info, I typed a reply a couple hrs ago but forgot to hit the submit button. you are right, when turned to backwash the water came out brown.
    Feb 2011
    Petaluma, Ca
    665
    Here are the test results from today: fc 10, cc 2.5, tc 12.5, ph 7.2, ta 150, ch 160, cya 0, temp 52.
    I am surprised the cya was at 0, I added a little too much chlorine but I think it will be gone pretty quick. He's not living there yet so this was just a temporary to reduce the algae, well go through the shock process soon. Right now its a 40 min round trip drive so it makes shocking virtually impossible. I guess we could throw some tablets in to increase the cya and keep some cl in there.
    Pool need attention to some details, I don't know much about these intex pools. Here are some pics of equip and pool.
    I forgot to look at the pressure before I back washed, but if the gauge is right it was 5 psi after. It took approx 1 minuet for the water to change from milky brown, to clear. Didn't take the top off today.
    The cl was 0 and the ph was 8.2+ when I first checked, so I got the ph level 1st.
    Feb 2011
    Petaluma, Ca
    665
    last pic, this needs some attention, I'm surprised it hasn't failed. The hose from the filter is not supported except by a bungee cord.
    22,548
    It needs a little TLC and a lot of chlorine. If you're confident in the CYA reading it wouldn't be a bad idea to throw a floater in there set wide open. It won't be shocking it, but it'll keep the growth down and will add some CYA. That way when you start shocking it will take a little less to accomplish it.
    Brown water coming out the backwash is a good thing. It means the filter is working. I'd go ahead and backwash it and put it back in filter and let it run.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by bobby1017
    My neighbor has this same pool and uses multiple bungie cords to multiple anchor points to control the direction of this outlet. This has worked fine for him the last 2 years. I think frogabog might have had a better solution, but I can't seem to find the post...others might as well.
    Feb 2011
    Petaluma, Ca
    665
    The test in the tf-100 didn't even hide the dot at all. I was surprised the cya was 0 but I guess either someone drained and refilled somewhat recently or they have always used liquid cl, I think the first option is more likely. I didn't see a floater anywhere though.
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by linen
    I guess there's not a "factory support" for it. We'll figure something out or maybe someone will post something. another question, where would a vacuum be connected?
