Results 1 to 9 of 9
Thread: How many tests in a K-2006 kit
    Feb 2012
    Brisbane, Australia
    28
    This might sound odd but I have not been able to find anywhere how many tests approx you will get from the standard taylor K-2006 kit. Would one of the taylor kit users be able to tell me. The reason I ask is I am in Australia and have to order the kit from the US. If I test at least once a week for most tests will the reagents last a year or should I order more reagents now and save the huge postage costs they charge to ship to Australia.
    15.8K gallons (60K Litres), IG, pebble, Davey 1hp 300lpm, sand filter, K Chlor SWG, Kreepy Krauly.
    Montreal Canada
    326
    Re: How many tests in a K-2006 kit
    The K-2006 uses 22 mL reagents.
    There are 572 drops per 22 mL reagent.
    You will be using more of one reagent than another while performing a test.
    For example, for 100 ppm TA water you'll be using 2 drops R-0007, 5 drops R-0008 and 10 drops R-0009.
    So the number of TA tests you can do depends ultimately on how fast you run out of R-0009.
    For each test the number of drops available (for 25 mL sample) is shown here:
    The lowest number in the "number of tests per reagent" column indicates the number of tests you would ultimately be able to perform with 22 mL reagents.
    Your mileage may vary of course depending on the actual makeup of the water and sample size (10 or 25 mL) , you'll run out of R-0009 faster if the TA is 300 than 20 of course.
    Feb 2012
    Brisbane, Australia
    28
    Thanks that is exactly what I need to know.
    The R-0870 is 10 grams and will do about 20 to 25 tests. The K-2006C (Commercial) comes with two bottles of R-0870. There are larger sizes of the R-0870 available.
    The K-2006 comes with two bottles of R-0013, which will allow 6 tests to be performed.
    Support the site
    hey guys, how long will the reagents be good for, seems like they will last me awhile since i dont check that often in the winter months, thanks
    Quote Originally Posted by kennyb30
    http://taylortechnologies.com/product_f ... fe_web.pdf
    Support the site
    Montreal Canada
    326
    The information I had was that 50 milligrams of DPD were required per *test* (I didn't note the source at that time) I have since then corrected that to 50 milligrams per *scoop* of DPD powder, 2 scoops are required. I've corrected the chart.
    I was also confused by the fact that you have the amount of reagent listed as 10,000 ml, but now it's clear that you mean 10,000 milligrams.
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by CaOCl2
    This implies 26 drops per milliliter but when I asked Taylor what the drop size should be and when I measured it in my own Taylor kit I got 24 drops per milliliter which is what they told me it should be (i.e. 24 +/- 1 drops per milliliter). So I think you should use 24 instead of 26 so that would be 528 drops per 22 ml reagent.
