Thread: Pentair SuperFlo 340044 2 speed wiring help
    Guest
    I have a new pump . I having trouble to figure it out how to connect the wires. I have 4 wires. green - ground, red - low speed, grey - common and black - high speed.
    But in th back of the motor is not clear where to connect what.
    I only have numbers 1,2,3,4,5 and 6
    Can any one help me?
    Jan 2012
    340
    Re: Pentair SuperFlo 340044 2 speed wiring help
    The green wire goes on the green ground screw, grey and black go on L1 and L2(doesn't matter which one) and your red goes on the other lug. I think they're usually labeled A or B. it's gonna be a screw on a post that sticks up higher than the other lugs. If it came with a factory installed switch, that will be disconnected when connecting to some type of controller
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Guest
    Thanks. I figure it out. the green is ground, the grey (common) in No 1, the black high speed No 2 and the red one low speed No 3. There is no L1 or L2 , just numbers.
