Thread: Where to drain outdoor island/sink
    I am in the process of planning an outdoor bar/island under my deck and am trying to figure out where/how to drain the sink. My back yard sits below the first level of the house, but I have a bathroom in the basement with a ejector pump to pump up to main sewage drain. Has anyone cut out a section of basment floor and ran that way or what are other options?
    15k freeform shotcrete sport pool 3.5-5-4, hayward swimclear c4030, 1.5hp hayward Northstar pump, polaris 280 with hayward booster, hayward turbo cell swg
    Riles_J's Avatar
    Nashville, TN
    218
    Re: Where to drain outdoor island/sink
    How does storm drainage get out of the area? I assume that you have some sort of positive drainage away. I have my sink just draining into a gravel area under my deck, as a temporary measure of course. I just don't use it for much except the occassional washing of hands and getting a glass of water. This is surely not up to code in your area, but I plan to plumb it into my sanitary some day. I have also heard of others that have created some sort of underground gravel leaching pit of sorts, but I am not familiar with the details. Digging up the floor to get into your basement plumbing sounds pretty extreme, but I'm sure it could be done.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    I think I'd dig a hole and bury a plastic barrel with a sump pump on a float switch to pump the water up to a drain line.
    why not a french drain
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    I did what JohnT indicated for an outdoor shower/sink. I took a 55 gallon plastic trash can and buried underground completely and filled it up with drain stone. I drain the shower in the drum. To-date after a year, I have not seen any ground water. I did put a bunch of holes in the trashcan throughout the sides and bottom for drainage. It works great.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
