Thread: A O Smith (Century) V-Green Pump Motor
    Does anyone have any experience with this motor: AO Smith / Century V-Green EMC27SQV ? I am looking at this as an energy efficient replacement for my Pentair Whisperflo. At first I was looking for a full pump like the Pentair Intelliflow or Hayward Ecostar. Replacing just the motor would save me a couple hundred bucks in equipment and installation. I know that I would be giving up something in not getting the whole pump.
    Unfortunately I cannot find everything that I need to know about the V-Green, like how does it achieve its efficiency and how that efficiency and life span compares to the the other two pumps.
    The V-Green is a variable speed pump (with a remote mountable control panel) so it gets much of its efficiency from that variable speed. The others are permanent magnet motors which increases efficiency and life span. I just can't find that information about the V-Green.
    Anyone know?
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,054
    Re: A O Smith (Century) V-Green Pump Motor
    Wow, this looks very interesting. I wonder what this will cost. I would like to have mas985 thoughts.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Best I have seen so far is $729, free shipping.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The V-Green also uses a permanent magnet motor. The efficiency should be similar to the EcoStar and Intelliflo but life span at this point is probably unknown given that the motor is fairly new. You can get most of the information from here:
    http://www.aosmithmotors.com/products/d ... 0737418318
    Mark
