Thread: Chlorine Concentration
    Mar 2011
    Houston, TX
    72
    Am I correct in assuming that now that I lowered my CYA to 40 and now can maintain a FC level of 3-5 instead of 7-12 when my CYA was over 100 that the concentration of chlorine in my pool is 1/2 to 2/3 less meaning clothes, pool floats, etc... wont' bleach out as fast?
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Chlorine Concentration
    Yes and I don't know.
    Yes, you can maintain a lower FC level and have the same protection you had.
    I don't know if things will not bleach out as fast. The higher FC was bound up to the higher CYA, so you should have the same available chlorine as before. I know that affects the sanitizing, I don't know if it works the same for bleaching.
    Mar 2011
    Houston, TX
    72
    Thanks Richard. I didnt really know if understood it either. I know the reason for the higher FC was due to the higher CYA bonding to the chlorine more but I don't really understand how that affects the bleaching action of swimmers and gear.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    My understanding* is that the higher FC for higher CYA is to maintain a common effective chlorine (oxidizing/sanitizing) level. This means, to me, that any bleaching effects should be the same. Hopefully, this shouldn't be a problem at normal recommended levels.
    *My understanding can be quite limited, as I AM an idiot.
    Mar 2007
    San Rafael, CA USA
    12,082
    Ohm_Boy, your understanding is right on. The active chlorine (hypochlorous acid) level that is what bleaches swimsuits and oxidizes skin and hair is roughly proportional to the FC/CYA ratio. So 10 ppm FC with 100 ppm CYA is roughly the same as 4 ppm FC with 40 ppm CYA in terms of its effects. The chlorine bound to CYA isn't completely innocuous, but its oxidizing power is 1/100th as strong.
