Thread: Covering Coping Joints
    I have a Spartan Vinyl Pool with 8" Aluminum Coping - Pool is 33 years old - unable to locate replacement plastic snap in covers for joints - any suggestions on what i might try to use to cover the small crack between the joints of aluminum coping - I have attempted to use caulking, gasket material with glue, but none of these solutions works for any length of time - Appreciate any suggestions
    South Central NJ
    3,192
    Re: Covering Coping Joints
    Owner of - PoolGuyNJ LLC
    Thanks Scott - I appreciate the link - I was surprise at the replacement cost of $21.98 for each clip, but when you have something old you have to pay.
    May 2015
    Kennesaw, GA
    29
    I have similar problem with old aluminum pool coping - see picture. The coping is 6.5 inches wide and mitered corners. Big gaps between each section. FYI, I've already checked w/ Cinderella.oldcoping.jpg
    Leo In Kennesaw, GA
    Older 40x20 rectangular pool
    38,000 gallons
    Vinyl In-ground - Buster Crabbe
    Pentair Chlorinator - Salt - SWG
    May 2014
    Towson, MD
    2
    The caulk between the aluminum coping and the concrete base is coming off. it's an old pool. I'm wondering what kind of caulking would be best to put a new look to this non-essential joint. It can't be any self-leveling caulk, but something needs to be like to fill a ≈1/2 cove.
