Results 1 to 17 of 17
Thread: Please recommend a good test kit
    Sep 2011
    Atlanta Ga
    310
    I am going to order a test kit from Amazon. Here is a list of the most popular
    http://www.amazon.com/s/ref=nb_sb_ss_i_ ... Caps%2C196
    Which would you recommend, or is there something better I could get at Home Depot or the local pool store?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Re: Please recommend a good test kit
    The K-2006 is very good, but be sure to look at the TF-100 kit (you can find references around TFP).
    J.Ollman
    18k gallon, in-ground gunite, attached spa, sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    22 posts and you haven't read Pool School yet? Tsk, tsk!
    Here's an article you need to read before spending any money: pool-school/pool_test_kit_comparison
    Aug 2011
    Metro Atlanta, Georgia
    161
    This one:
    Taylor Complete FAS-DPD Water K 2006 if you are locked into Amazon. I also use and recommend a speedstir and samplesizer
    IMO, a pool like mine (and your's) needs a minimum of the TF-100 or K-2006, the other test kits are not going to cut it and just forget the strips for general tests (come by, I'll give you some). I thought enough of the TF, that I bought one for my brother, with a speedstir, to stop the problems he was having caused by inaccurate test strips and pool store advice.
    Basically, a TF100 is all taylor reagents, with different packaging. I get great service, quick answers and the owner is usually on the forum to catch any questions or problems. The test results are same as a Taylor. http://tftestkits.net
    You might read this benefits-to-the-speedstir-for-the-tf-100-t33267.html
    +1 what Richard said,
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    Aug 2011
    161
    Quote Originally Posted by TomAtlanta
    Sorry, I didn't answer all the question!
    Home Depot, Target, Kmart and Walmart stuff is pretty elementary. I have never seen Taylor products anywhere locally, except in a pool store. So, these places, no.
    So far as pool stores go, it's been a while, but when I tried the 2 Leslie's close by, they had nothing with the FAS/DPD Chlorine Test; either in a kit or in individual reagents. And the locally owned store, around the corner, would be glad to order what I wanted. YMMV depending on what part of town you are in.
    Prav's Avatar
    Nov 2010
    Miami, FL
    94
    +1 on TF-100
    14'x30' (est. 14K gal) w/spillover spa (est. 500 gal) - 1995 // Diamond Brite Blue Quartz - 2006
    Hayward SwimPure Plus T-15 - 2013 // Zodiac MX-8 - 2013
    Plain ol' Intermatic mechanical timer // Pump: 1½ HP Pentair SuperFlo - 2012
    Filter: Hayward C17502(S) Cartridge Filter - 2011 // Heat Pump: Sunrunner/Aquapro 1300 (127K BTU) - 2011
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Not to be redundant...but I fourth the tf-100 recommendation. I think the amounts of reagents and the packaging is better than the K-2006. In fact...buy two to share (I did) ...
    Puffin's Avatar
    Jul 2010
    217
    +1 TF-100
    I have one and am happy with it.
    Look at Richard's for alternatives.
    the speedstir burford pointed out is worth a look as well. It's not a test kit but pretty handy for testing.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    If the cost of the TF100 or the Taylor K2006 troubles you, look at it this way. A high quality test kit is an investment in the health of your family and your pool. The chemicals will last for a year or more of normal use when stored in a cool (normal house temp) dry environment. The range of tests performed by these kits will enable you to keep the water sanitary, so it is healthy to swim in, and balanced, which protects the plaster or liner from premature failure.
    It will also save money in the long run, so you will not feel obligated to buy pool store chemicals when they perform those tests for "free". As an added bonus, your results with either kit will often be more accurate than the pool store tests.
    Personally, I prefer the TF100 as it will give you larger amounts of the test reagents than the Taylor K2006, and the customer service is exceptional.
    Love TFP? Become a
    TFP Supporter!
    Aug 2011
    161
    Quote Originally Posted by Puffin
    +1 TF-100
    Another brain ... uh, senior moment. ugggg
    Sep 2011
    Atlanta Ga
    310
    Thanks for the info everybody. I'll get the TF-100 with the speed stir. I prefer amazon because I know their reliability and policies, but I assume from all the positive comments here that service from the TF-100 site is also good.
    27000 gallons
    Pool built in 1971.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I would go ahead and say that the TF-100 site is much better than amazon.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    Sep 2011
    Atlanta Ga
    310
    The TF-100 and speed stir have arrived. The speed stir has a tiny little Phillips head screw that I need to remove to get the batteries. I have a tiny phillips head screw driver, but even it doesn't work. I guess I will need to go the hardware store and get a special screw driver to open it and add the batteries. I think this is a poor design.
    27000 gallons
    Pool built in 1971.
    Dec 2010
    San Diego, CA
    1,137
    I think I used a standard #2 phillips...I definitely didn't bust out the precision set or the eyeglass repair kit. Maybe your screwdriver is worn out?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Well, I look at it this way - if that's the only problem you have with your test kit and speed stir, you'll only encounter that problem once a year. It works great otherwise.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Maybe poor, but is a common design (at that price point) similar to all of my kids cheap remote control battery doors etc. You should be able to open it with a sharp knife tip, etc. Many ways to skin that cat.
    22,543
    I think they're size "0" (ought) phillips. While it's not too common, it's certainly not anything special. As said before, it's something you'll only have to deal once a year or less.
