Results 1 to 11 of 11
Thread: New AutoPilot SWG Install
    Mar 2008
    Pelham Alabama (Birmingham)
    69
    I will be installing my new AutoPilot soon. I was planning on how\where I am going to install the manifold. My system currently has a tablet chlorine inline feeder. With the possible future need of needing the tablets/pucks to add CYA, I've decided it would be a good idea to leave the chlorine feeder as part of the system. So now for my question. Is the better to have the chlorine feeder before or after the AutoPilot in the piping? Or does it matter? Or is one way maybe slightly better, or not. In my system, I'm thinking it would be easier to mount the chlorine feeder before the AutoPilot, but either way is possible. So chlorine feeder first, Autopilot first. What do you think?
    Mister Mister
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
    Hayward S244 Sand Filter
    Hayward 1hp RS1000 Pump
    Leisure Bay Spa - Flores - 500 Gallons
    AutoPilot SpaPilot - Not Yet Installed
    Guest
    Trichlor is not the best way to add CYA to the water when needed. It is actually more expensive then just adding CYA directly. . I notice you have a sand filter so you will need to be adding CYA and salt on a regular basis to maintain what is lost by backwashing.
    Mar 2008
    69
    Forgive my ignorance, but how do I and CYA directly? I thought I had read that CYA can only be added with the "pucks". I am obviously confused. Can you clarify for me please?
    Mister Mister
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
    Mar 2008
    69
    Also, can the AutoPilot "controller" be mounted to where it is exposed to the weather? Are there any special Summer/Winter climate considerations? Should it be removed during the winter? Should it be mounted in some type of weather resistant box??
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
    The AutoPilot systems are designed for outdoor mounting.
    Jul 2007
    Brisbane, Australia
    874
    i couldn't find the IP rating of it, so cannot comment how water proof it is, but i would at least cover it from direct sun light.
    Generally it's a good idea to have a cover for all your equipment, to shield it from weather.
    Mar 2008
    69
    Thanks for the info Strannik.
    So, therefore, do you think I should install/reinstall the inline Chlorine feeder at all?? Does not sound like I should need it. ??
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
    Jul 2007
    Brisbane, Australia
    874
    Unless you plan on selling it on eBay or it really gets in a way of SWG installation i would leave it there just for the sake of it.
    Ft Lauderdale, Florida
    1,455
    Mister Mister,
    The AutoPilot control box is approved for indoor or outdoor locations and does not need to be protected from the weather. As Strannik mentioned, it's a good idea to shelter it from the weather, but again, it is not necessary. It would normally be mounted to a wall. If you are mounting it to a post, there are some vent holes in the back that would need to be sheltered, and I would therefore recommend mounting it to a board, then to the post.
    Regarding the position of the manifold, AutoPilot first, then tri-chlor feeder because of the corrosive nature of trichlor (low pH and high chlorine). This can cause corrosion to the tri-sensor assembly. It will not harm the cell though.
    I should say though, that you really don't need to keep the tri-chlor feeder. Just get rid of it.
    Thanks for selecting AutoPilot.
    Cya is available in granular form. It should be added right after backwashing your filter. It takes time for the cya to fully dissolve, so do not backwash your filter for at least one week after adding the cya.
    Also, there are some suggestions as to how to efficiently add the cya. Using an old panty hose without holes, fill it with cya and position it in front of your return jet.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Mar 2008
    69
    Thanks Poolsean,
    Your advice, as usual, is very helpful. I think I'll leave the off. If at some point in the future I need it for any reason, I'll just re-install it at that point.
    Thanks again,
    Mister Mister
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
