Results 1 to 9 of 9
Thread: Do I need tiles at the waterline?
    Aug 2010
    Charleston, South Carolina
    77
    Are the tiles at the waterline necessary? Like keeping the pool finish below the water line. Or are they installed strictly for aesthetic reasons? I'm wondering if I could omit them all together.
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    Re: Do I need tiles at the waterline?
    Most pool finishes are designed to be kept underwater. Can't think of any that aren't, but I'm not a pool guy. You'll need something at the waterline and tile is probably the least problematic and easiest to clean. Some people use flagstone (like me), but you'll need to be very careful if you choose a natural stone as, depending on its composition, it could deteriorate.
    Shelley
    Denver, CO
    Nov 2011
    Moberly,MO
    1,010
    What kind of pool. Gunite, fiberglass, vinyl makes a diffence.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I've seen pools with pebble finishes with no waterline tile. It makes it very hard to clean.
    Aug 2010
    77
    sorry, it would be gunite. Sounds like everyone agrees it makes it harder to keep the finish clean.
    Jun 2011
    Flower Mound, TX
    37
    When we were shopping, one PB offered that as an option with a pebble finish. He showed us some pictures, and it looked pretty good. Different, but in a good way.
    20' x 40' / 33,000 gallon / IG / Vinyl
    200lb sand filter / 1hp pump
    4hrs full sun with about 45 min part sun before and after
    Apr 2010
    Buckeye, AZ 85326
    619
    I like the way it looks with the pebble tec all the way up. I think its called rolled bond beam? But we went with the hind sight of other pool owners and had the water line tile installed due to cleaning issues.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    I have a pool on my route that was diamond brite all the way to the coping. no waterline tiles. water got under the coping and the pool finish is falling off and the patio is all cracked up. Of course these builders did not seal properly between the finish and coping but best to install waterline tiles. it looks better and diamond brite will eventually crack up in the sun if exposed above the water. we did do a waterfall and some finish is exposed at the very bottom but we keep the waterfall on as much as possible to keep it wet. we only did this on the bottom as the pool owners ran out of tile and wanted the tile section of the fall centered. they were using some old tile they had left over and no one manufactures it anymore..at least we could not find it anywhere. it's been 2 1/2 years and all is still good with the finish.
    but best not to cut corners and get the waterline tiles.
    after a few years pebble tec will crack if it has been installed above the waterline. I did this on my old pool and it cracked horribly.
    Shelley
    Denver, CO
