Thread: Back up valve
    Aug 2011
    Frisco, TX
    26
    Back up valve
    Back up valve appears to be stuck in back up mode. It is a Polaris back up valve but I have a pentair Legend
    Before buying a new back up valve, anything else I should check?
    14,000 Pebble Sheen Salt Water Pool All Pentair Equipment/ Cartridge Filter, 400K BTU Heated.
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Back up valve
    Check to be sure the back up valve is stuck or is it a split in the case. The case can be replaced cheeper then the whole unit.
