Thread: Aqualogic AQL-P-4 Odd panel readings- Help
    Nov 2011
    Magnolia Texas
    80
    My Goldline Aqualogic AQL-P-4 has been shutting down recently when the chlorinator tries to turn on. I just took some readings and need help in pinning down the issue. On the pump relay the low voltage side that connects from the relay to the logic board is reading 48.5 volts which is double what it should be. Between the main transformer and the logic board I measured at the two orange wire where they connect into the logic board. The voltage was .2-.3 volts. Correct voltage should be 20-24 volts. finally, there is a red and black wire between the main transformer and logic board. They again read 48.5 volts. The range should have been 18-33 volts.
    Is my transformer bad, my logic board or both? I need to do something quickly as I will need to start using my salt water chlorniator again here in the next month or so when it warms up. Thanks!
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    South Central NJ
    3,192
    Re: Aqualogic AQL-P-4 Odd panel readings- Help
    Check the legs off the transformer first.
    Scott
    Owner of - PoolGuyNJ LLC
