Results 1 to 9 of 9
Thread: Spa water level dropping
    jimrockford's Avatar
    Aug 2011
    Tampa, Florida
    16
    My pool has an attached spa with a spillover. Usually, the water level in the spa is several inches higher than the water in the pool, but for the last few days, the water level has dropped steadily during the evening after the pump has stopped running for the day. It seems like the water is draining back into the pool from the spa until the water level between the two bodies of water are at the same level.
    Why has this started happening? Or, more importantly, why didn't this happen before? Is there a one-way valve that is supposed to prevent it?
    9000 gallon in ground plaster lined pool with spa
    Pentair Clean & Clear cartridge filter
    Pentair IntelliFlo Variable Speed Pump
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Spa water level dropping
    Yes it is called a check valve and sometimes they will get old and not seal as well. If it is the type with the clear lid that has screws, then you can inspect/repair them. If not and you determine that is the cause, you may need to replace it.
    Mark
    Aug 2011
    Tampa, Florida
    16
    I see a check valve with a clear window on one of the pressure side lines. How can I tell if it isn't working? And, if I open it up to fix it, won't I have a geyser on my hands?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Is the check valve below the water line? If it is, there should be isolation valves to prevent the water from gushing out. Anyway here is what you need to do:
    Turn pump off
    Close isolation valves if you have them
    Drain filter by opening the air bleeder valve and remove pump lid
    Unscrew the valve cover
    Inspect the valve flapper for any tears and/or cuts
    If fine, relube and reinstall; if damaged, replace
    Also, if you have pool spa valves, if the valve does not seal, the spa can drain that way as well. The valves can be inspected the same way as the check valve.
    Mark
    Aug 2011
    Tampa, Florida
    16
    The check valve is above the water line. Not sure what I was thinking.
    The valve looks like it's in decent shape, so hopefully it just needs to be lubed. If not, can I swap the flapper from an identical valve or will I need to completely replace it?
    Dec 2010
    San Diego, CA
    1,137
    You can swap the flapper ... At least I know you can if it's a pentair valve. You just slide the SS pin that the valve rotates on out. I used a small awl. One side will be abraded to hold the pin - tap it out from the other end. I assume the same is possible with jandy brand valves bu I don't know for sure
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    mas985's Avatar
    Pleasanton, CA
    11,741
    Not only can you swap the flapper but you can also just purchase the inside of the valve.
    http://www.poolcenter.com/parts_valves_ ... 1_7512.htm
    Mark
    Aug 2011
    Tampa, Florida
    16
    Thanks for the advice. Looks like I have a project for this weekend.
    nutjob's Avatar
    May 2011
    Dallas
    109
    This happens to me occasionally when switching from spa mode back to pool mode. One of my valve actuators (on the suction side) doesn't close off the spa drain completely, so it's about 15% spa drain and 85% main drain. The actuator on the other side works reliably, so it's 100% pool returns. The result: water from the spa slowly drops, the pool level rises, and the overflow drains into the back alley.
    Switching back to spa mode and then pool mode a few times helps.
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
