Thread: Hayward gas heater repair questions
    linda1's Avatar
    Mar 2010
    Western Pa.
    296
    I have a Hayward natural gas heater. It has been use lightly, maybe 5-6 hours total. It just started acting up last spring. Would turn it on and it would be fine then later I would notice that it had a CE code. Sometimes the code would go away and it would fine. Sometimes from the code the display will just go blank. We turned the heater on each day, but mainly to see what the water temperature was. My husband took the cover off to check the two main boards. The picture below shows an area that appears to be fried. (center bottom of board) Is it safe to assume that this is the board that needs replaced? Does anyone know of a place to get just the R15 part? Last summer I check around for a new boards and they were running around $200 each and I'm trying to save a few dollars if possible.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    South Central NJ
    3,192
    Re: Hayward gas heater repair questions
    Without the schematic of the board, it could be a diode, resister, thermistor.... I would encourage swapping the board. Also check the transformer that feeds it for the correct output voltages.
    Scott
    Owner of - PoolGuyNJ LLC
    linda1's Avatar
    Mar 2010
    Western Pa.
    296
    Scott, thank you for your reply. I'll just order a new board.
