Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Baquacil conversion underway in Florida....
    First time poster here.
    I read many many posts on conversions, and have read the steps in Pool School, and have been performing the conversion on my 10,000 gallon plaster pool.
    I had used Baquacil for 3 years prior, and used the CDX product for 2 of the 3 years. Prior to converting, I let all my Baq levels go down to zero. Water was very cloudy and could not see the bottom.
    I am 10 days into the process. Water is clear in that I can see the bottom very clearly, however, the water is tinted green.
    Pool Parameters at the start (Using the TFT100 test kit):
    FC 0
    CC 0
    TA 60
    CYA 0
    CH 420
    I was putting chlorine in hourly for the first 4 days and brushing/vacuuming daily. At that point the water was clear, but tinted green. Have been shocking nightly since then. Overall I have put in 72 gallons of 5.25% bleach.
    The CC reading is continually very high, and has not come down anywhere near 1. Today's figures:
    1-31 Evening FC: 20 CC: 6
    2-1 Morning FC 12 CC:16
    My pool has a cartridge filter (Pentair). The first week, there was a huge amount of orange scum in between the pleats. I hose it out daily, but that orange goop is still is in there that I can see, not a lot, but in there nonetheless. Could that be the source of my high CC? Should I just wait until the CC comes down before changing the filter?
    Thanks in advance for the feedback!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Baquacil conversion underway in Florida....
    Need the technicolor show
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Yeah its not a good conversion without pics.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    I would think there was quite a bit in nooks and crannies of the piping, equipment, heater and filter. Patience and more bleach friend. It doesnt help we havent had much direct sun to break down the ccs.
    2-2 9:00 PM
    FC 22
    CC 6
    2-3 6:00 AM
    FC 15
    CC 8
    I have some pictures, will try to post them tonight.
    30,431
    That FC loss of seven overnight certainly indicates you have a ways to go. Hang in there. It's hard to be patient but as long as your FC diminishes (more than 1ppm) overnight, then you know you are oxidizing organics and need to keep the FC up high.
    I'll bet your FC usage will diminish rather suddenly and you'll see fast progress on your water clarity.
    2-3 9:00 PM
    FC 17
    CC 14
    2-4 6:00 AM
    FC 13
    CC 11
    Here are some pictures
    At the start
    [attachment=2:3q8xzdn3]IMG_0209_r.jpg[/attachment:3q8xzdn3]
    [attachment=1:3q8xzdn3]IMG_0210_r.jpg[/attachment:3q8xzdn3]
    This is really gross.....
    [attachment=0:3q8xzdn3]IMG_0212_r.jpg[/attachment:3q8xzdn3]
    Here are some more....
    [attachment=2:13kjtybq]IMG_0214_r.jpg[/attachment:13kjtybq]
    [attachment=1:13kjtybq]IMG_0216_r.jpg[/attachment:13kjtybq]
    [attachment=0:13kjtybq]IMG_0218_r.jpg[/attachment:13kjtybq]
    Here are 2 from this afternoon
    [attachment=1:23r3uisd]IMG_0227_r.jpg[/attachment:23r3uisd]
    [attachment=0:23r3uisd]IMG_0228_r.jpg[/attachment:23r3uisd]
    Hope you enjoy these.....
    Oct 2007
    Cedar Hill, TN
    252
    Hang in there!!!
    My water looked green for quite a few days, too.
    Then, all of a sudden the green was gone!!! It has been perfectly clear ever since. (3 years)
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    2-4 9:00 PM
    FC 19
    CC 9
    2-5 6:00 AM
    FC 13
    CC 14
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Just keep it up! You will get there soon!
    Mar 2007
    San Rafael, CA USA
    12,082
    Because of the use of CDX, it will take longer. It's a chemical that is harder to get rid of than Baquacil/biguanide/PHMB alone. CDX is mostly DMH which is the foundational core in bromine tabs and is somewhat analogous to CYA. Though chlorine will slowly get rid of it, sodium percarbonate gets rid of it faster (but is more expensive and should be used before any chlorine is added).
    2-5 9:00 PM
    FC 18
    CC 8
    2-6 6:00 AM
    FC 14
    CC 10
    2-8 9:00 PM
    FC 18
    CC 5
    2-9 6:00 AM
    FC 15
    CC 6
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    BullGator...WE NEED MORE PICTURES
    The pool is crystal clear now, no more green tint.
    I think I am getting closer now. tonight's reading showed CC down to 3, which is lower than it has ever been. Will see how much FC drops overnight. Has been dropping 2-4 points per night lately.
    That CDX stuff is hard to kill ......
    Still adding the bleach as needed. Running low on test drops, I ordered more last night from TFTestKits.
    I will try to take some pictures this week and post. There really is no exciting colors to see here.... just clear
    2-13 9:00 PM
    FC 20
    CC 3
    2-14 6:00 AM
    FC 15
    CC 3
  20. Back To Top    #20
    2-15 9:00 PM
    FC 20
    CC 4
    2-16 6:00 AM
    FC 14
    CC 2
