Thread: Replace filters or change to sand filter
    Oct 2009
    Cumming, GA
    13
    it's time (past time actually) to get new filters for my Jandy CL580 Cartridge filter. that's gonna run about $300. should i just rip it out and put in a sand filter? pool/spa is about 16000 gallons.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Replace filters or change to sand filter
    Depends on what you're looking to accomplish. The nice thing about a cartridge is you don't have to back wash it. Rinse and replace.
    Some reading: pool-school/pool_filter_comparison
    What makes you think they need replacing? Years? Do you use skimmer socks? I'd guess that using them would make any replacement based on years of use somewhat invalid.
    Too fast a pressure rise after cleaning? How have you cleaned them? Does your water have high CH?
    Where are you located? (please add that to your profile so we can see it when you post -- see bobo's above) If you are in arid areas subject to water restrictions then you may not want to waste water with frequent backwashing.
    I replaced my carts just last year. Got a slightly cheaper brand and they are a smidge too small ID to fit on the cart holders correctly. Kinda wish I'd paid up and gotten original brand to replace. I was concerned about the broken bands on my carts, later read that this may not be all that important. Now I run the pool with skimmer socks in place at all times and the carts stay clean much longer.
    Oct 2009
    Cumming, GA
    13
    I'm in Cumming, GA. - north of Atlanta. They have never been replaced since the pool was built in 2004. The bands are broken and they don't seem to come very clean. I have been using the skimmer socks but only since last year.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Clayc
    Have you been happy with your old filter? Are there some problems or issues you'd like to try and address/fix with a new filter? If not, I'd just stick with what you got.
    Your current filter is pretty large, which is great! Finding a new sand filter of comparable size (especially with installation and new sand factored) is likely to be more than $300. Depending on what you like and don't like about your current filter, the differences may not be something you'll be happy with.
    As far as the cost, I know there are a few companies that make less expense replacements (than OEM) and people here have reported they are happy with them. I don't have a cartridge filter, so I don't have any experience with these brands. However here is a link where some of these brands are discussed. http://www.troublefreepool.com/repla...ws-t20193.html
    Hopefully others who have bought the alternative brands will post and give you some input. anonapersona, what brand did you get?
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Oct 2009
    Cumming, GA
    13
    thanks. i'm happy with the way it performs - it's just a pain to clean as would be compared to backwashing. i didn't know there were any non-oem brands. i will look around. thanks.
