Results 1 to 7 of 7
Thread: Water on cover
    May 2011
    Los Angeles, CA
    228
    Water on cover
    Hello everyone!
    I covered my pool yesterday for the first time and this is the first time I have ever used a pool cover.... (Still new pool owner)
    Today i have 6-8 inches of water on the pool cover. Do pool covers let water through them and do they have to be regularly pumped out?
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Water on cover
    What kind of cover do you have?
    donaldm823's Avatar
    Cape Coral, FL
    147
    Re: Water on cover
    Looks like you have a solid cover since you have 8in of water on top of the cover. Some covers are mesh. My solid cover came with a "Rule Pool Cover Pump" that keeps the pool cover dry and it works well. It auto cycles and stays running if it senses water in the pump suction. Attached is a source on Amazon
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    May 2011
    Los Angeles, CA
    228
    Re: Water on cover
    It is a solid cover which i brought on ebay. I didnt know that even solid covers have to be pumped out!
    SW Indiana
    9,199
    Re: Water on cover
    Unless you have had that much rain, which I doubt, you have a leak in the cover.
    May 2011
    Los Angeles, CA
    228
    Re: Water on cover
    I will pump it out and see if it fills up again... it might have been when the pool pump came on, it poured water onto it from the spa's overflow...
    Thanks for all the help!
    SW Indiana
    9,199
    Re: Water on cover
    Quote Originally Posted by Suley
    Ah! Pump back into the pool under the cover when you do.
