Results 1 to 19 of 19
Thread: Which SWG is a better value
    Apr 2009
    New Orleans
    17
    My Intex cheapee finall died so I need a real SWG for my 8k AGP.
    I have 2" piping and a 250# sand filter so I'm rigged like a IGP.
    Which would be a better value a CircuPool RJ20 with a 7 yr warranty for $549 or a Intellichlor IC15 By Pentair for $389 ?
    12x24 AG 8.7k, 27" sand filter w/1 HP 2 speed Dynamo ,1 main,1 skimmer and 2 returns, 2" PVC
    22,548
    Re: Which SWG is a better value
    Either of those units will be fine. The Intellichlor is a heck of a buy at that price.
    Apr 2009
    New Orleans
    17
    Bamma, will the IC 15 be overpowerd enough for my 8k pool ?
    22,548
    It's designed for 15,000 gallon pools so it should be great.
    Apr 2009
    New Orleans
    17
    Good deal, got it ordered..thanks !
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by divinduck
    Did that price include the power supply?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Aug 2007
    near the swamp
    806
    yeah that sounds like the cell only, but if it includes the power supply than that's cheaper than my costs lol
    Dec 2009
    2,690
    Quote Originally Posted by DBfan187
    Question is, if it doesnt, did divinduck order a power supply?
    Aug 2007
    near the swamp
    806
    well that is right inline with the power supply's cost
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The intex of course!
    Apr 2009
    New Orleans
    17
    Yes it came with a p/s, but it is a smaller sealed unit not the bigger power center.
    And that was $389 TOTAL, no shipping no tax and no handeling !
    Dec 2010
    San Diego, CA
    1,137
    Where did you get that deal?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by carlscan26
    I second that question!
    Apr 2009
    New Orleans
    17
    National discount pool supplies
    Dec 2010
    San Diego, CA
    1,137
    Why does it say that for above ground pools you don't need the PS? The other cells indicate the need for a PS. And they seems to say that if this one is used for an IG pool it also needs a PS?
    Dec 2010
    San Diego, CA
    1,137
    Also, are the cells interchangeable if you decide you want a bigger cell is that doable without re-plumbing?
    22,548
    The IC15 doesn't need the power "center" like the larger units but it still needs a power supply.
    Dec 2010
    San Diego, CA
    1,137
    ...and that price is gone
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    If you're not looking for a lot of bells and whistles if you compare output amounts divided by cost it may give you an idea of value. All SWCG units wear out, they have a fixed life expectancy (total output)and its a function of run time and output percentage run. It's basically if you run it at 50% it will run twice as many hours as 100%. That's how it works on paper, real world conditions will vary.
    MODEL Production rate lbs/day Price (2/12) Rate/Price Lower better!
    CPSC 48 2.5 $735.00 294.00
    CPSC 36 1.9 $625.00 328.95
    CPSC 24 1.3 $541.00 416.15
    IC20 0.7 $750.00 1071.43
    IC40 1.4 $850.00 607.14
    IC60 2.0 $1,100.00 550.00
