Found my Auto Fill leaking externally from where the PVC connected to the housing. After turning it on for about an hour the landscaping around the pool deck was muddy and saturated with water, although the fill valve had shut off. I dug a hole and the leak is clearly comming from the conneection, so I have shut off the water flow to the auto fill.
My problem is very little room to reach or work from the hole I have dug.
Is there a way to remove the canister from the pool decking??
Thank You for any help in advance.
