Results 1 to 10 of 10
Thread: Just received my TF100, here's my readings
    FC-5
    CC-0
    PH-7.5
    TA-80
    CYA-45
    I didn't realize the difference between this test kit & the ones you get at WM. I understand now why you guys recommend getting a high quality test kit. I think everything looks good (i'm not really sure) except for my CC. Any suggestions on what I need to do?
    Thanx,
    Gdog
    28' round 23k gallon AGP Vinyl Liner
    1.5 hp pump,Sand Filter,Polaris 65 8 gallon Liquidator
    You want CC to be zero, so no problem there.
    Your numbers look idea if you are using bleach or a SWG. If you are using trichlor pucks for chlorine your TA is a little low.
    I'm BBB all the way now. My water looks much better than it did when I used all the pool store chems.
    Thanx for the quick response. I guess I just need to maintain with bleach now right?
    Gdog
    30,431
    That'll be about it. Many pools will tend to show a little pH rise (mine does) but it's pretty slow....I add acid about once a month, if that.
    You should be able to use the small block test for chlorine and pH every other day or so for a little, then you'll probably know how much chlorine to add without even testing. Probably once a month, break out the whole kit and do all the tests to make sure everything is still in line.
    Of course, if your water quality shows some deterioration, do a full set of tests right away. Thanks again for your business.
    Thanx for puttting together a test kit like this. It is soooo easy to use.
    Thanx to all of you for sharing so much information.
    Gdog
    Guest
    Re: Just received my TF100, here's my readings
    Quote Originally Posted by Gardog
    I didn't realize the difference between this test kit & the ones you get at WM. I understand now why you guys recommend getting a high quality test kit.g
    SHOUT IT FROM THE MOUNTAINTOPS! HALLELUJAH BROTHER, HALLELUJAH AND AMEN !
    I did another test today, (this is really fun) & my CH is 1600. I didn't check this the first time & just did it out of curiosity. What would cause this reading to be so high? My water is really clear. Is this something to be worried about? I'm using a vinyl liner & I am using BBB.
    Gdog
    30,431
    Gdog,
    Operator error!! Please don't take that as a smart a** remark.....there is a pretty good chance that's the issue.
    Review the procedures and make sure you're using the right chemistry. When you first get the kit, it's pretty easy to get the wrong bottle or do the math wrong or some little thing that will throw off your results.
    I have never seen CH that high posted here on the forum.....let's hope it's not really accurate.
    I hope that is what it is!!!! I'll go right now & check to see & follow instructions to the tee.
    I'll be back in a minute
    Gdog
    Moderator,
    Can you please delete my last post about my CH level at 1600. I'm such an idot
    My CH is 170ppm.
