Thread: salt water system or chlorine
    We are installing a new inground pool in Pennsylvania (central). We have never own a salt system, our PB is highly recommending one instead of a traditional chlorine system. Any recommendations would greatly be appreciated before I decide to put down money on a contract. Glad I found this site!
    Thanks
    Wheelman
    Simply, we find, hire and train the most talented individuals possible and we work hard to keep them.
    Autoform
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: salt water system or chlorine
    A salt water system uses chlorine but it produced at the cell through electrolysis.
    Some good reading: pool-school/salt_water_chlorine_generators
    I strongly recommend one it makes pool care much easier. No lugging jugs of chemicals (bleach) to the pool, and it maintains a more consistent chlorine level in the pool. They typically run in conjunction with the pool pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Quote Originally Posted by wheelman73
    Thanks
    Wheelman
    Does PB mean a tablet feeder when you say "traditional chlorine system"? If so, SWG is world's better. If he means a reservoir and a pump, it's still better. You add salt and let it run. "Refill" once a year...
    Apr 2011
    Murrieta, CA
    2,360
    Refill means to top off salt level due to splash out or draining to waste/backwashing, not a full drain and refill. That's another nice thing about SWCG. The salt doesn't evaporate or go away.
