Thread: Calcium Hardness in Fiberglass SWG Pool
    What is the purpose of CH in a fiberglass SWG pool? What is the recommended level for my pool?
    Thanks for your help!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    South Central NJ
    3,192
    Re: Calcium Hardness in Fiberglass SWG Pool
    Some manufacturers want it to protect the gel coat. I have never seen any reason other than sympathy for the chem companies though. As long as the basics are covered, care is the same as for a liner pool.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2007
    San Rafael, CA USA
    12,082
    Some gel coats have calcium carbonate filler so to be safe we recommend the same CH levels as for plaster pools. If you know that your gel coat is not made with a calcium carbonate filler or backing, then the CH level could be set to that similar to vinyl pools (i.e. doesn't need to be as high).
    I usually maintain above 250ppm CH in Fiberglass pools, and above 200ppm CH in concrete pools. That won't hurt anything.
