Thread: Drain and Refill
    Mar 2011
    Houston, TX
    72
    Drain and Refill
    Just drained 60% of my water in order to lower CYA. Now refilling. Shoud I add some bleach during the refill? Thinking about putting a gallon in tonight before I go to bed. I think I drained around 10,000 gallons so I assume mixed with the existing water it should be fine. What else should I do during the refill?
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Drain and Refill
    Quote Originally Posted by brownchristian
    Run the pump to mix it good. Well, if you can. If you're below the skimmers it'll have to wait.
