No vacuum
Jul 15, 2011
24
Henderson, NV
Hello all,
Ok when I have my valves set for the main drain or skimmer the pump pressure is aroun 35. When I switch it to cleaner to use the hose to vacuum the pressure drops to 0 and the pump drains. No vacuum from the hose at all. If I switch back it immediately picks back up to 35 and the jets purge air. This is my first pool, any help is great. Thanks.
