Thread: No vacuum
    Jul 2011
    Henderson, NV
    24
    No vacuum
    Hello all,
    Ok when I have my valves set for the main drain or skimmer the pump pressure is aroun 35. When I switch it to cleaner to use the hose to vacuum the pressure drops to 0 and the pump drains. No vacuum from the hose at all. If I switch back it immediately picks back up to 35 and the jets purge air. This is my first pool, any help is great. Thanks.
    Henderson,NV
    15x30 IG plaster; 18,500 gallons; Pentair 420 cartridge filter, WhisperFlo 2.5 HP SF 1.30;
    Autofill from tap water
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: No vacuum
    Are you filling the hose with water before you switch to the vacuum?
    Jul 2011
    Henderson, NV
    24
    Re: No vacuum
    It's submerged. But there's no vacuum at the plug on the side either
    Henderson,NV
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: No vacuum
    If you could post pictures of your equipment pad and pool that would help us identify the problem.
    Love TFP? Become a
    TFP Supporter!
